XJ ( X351 ) 2009 - 2019
2014 XJ Workshop Manual
Old Sep 2, 2017 | 02:09 PM
clubairth1's Avatar
Community Influencer
Default 2014 XJ Workshop Manual
After much searching I finally found a PDF version for $16 to download.
All 8669 pages! Looks to be the factory deal and it's fully searchable and has a good set of book marks laying out the chapters.
Got it from CARMANUALS4U UK;
https://www.tradebit.com/filesharing.../0/jaguar+x351
It looked a little shady (plus not sure why they have a different manual for every year?) but I figured I could lose the $16 just to see. Worked fine and got a download link in about 15 minutes after I paid with Paypal. After paying you are sent a file that has an email address which you send you car info (Make and model) along with what type of computer you have Windows or Mac. You get a download link to the PDF (mine was 98 MB).
Have found the later JEPC (Parts Catalog) too but it's $100. So still looking at it.
https://www.5obd.com/jaguar-jepc-vin...?search=jaguar
Old Sep 4, 2017 | 02:29 PM
Enosgl's Avatar
Great find. I downloaded for my 2012 XJ s/c. For $15.00 USD to have the entire manual on my notebook wherever or whenever, it is priceless.
Old Sep 5, 2017 | 11:49 AM
XJsss's Avatar
Thanks I purchased and downloaded.
Old Sep 8, 2017 | 08:10 AM
TheBoy's Avatar
If you don't mind illegal downloads, I think you are all paying too much.
But as I do not believe in stealing, I will not suggest where to get stuff.
Old Oct 8, 2017 | 05:17 PM
NorcalJag's Avatar
Score for $16.00
It is the same as info we get off of Topix right?
Old Oct 9, 2017 | 09:50 AM
clubairth1's Avatar
It sure looks like it to me.
That's what I was looking for. It's a massive manual and the only complaint so far is my inability to use and find stuff!
Now to find the JEPC.
I found one but they want $100 which seems very high?
Does anyone have the later say 2017 JEPC. I have an earlier version that covered my old 2005 STR and it was very useful.
Old Oct 10, 2017 | 07:28 AM
Serlock's Avatar
go to itopix, pay 100+gbp for a monthly subscription and download every possible info, diagram, manual about your jag.
Old Oct 31, 2017 | 01:32 PM
Quartzboy's Avatar
I'm sure it's in there but is there a section on how to change the oil, brake pads, and engine air filter? It just so happens that my 2011 XJ needs these items to be performed and I would MUCH rather do it myself than pay the dealer $800+ to do these items.
Old Nov 1, 2017 | 05:29 AM
rhomanski's Avatar
I didn't see it in my quick scan, but I'm pretty sure it will be there. I downloaded the 2012 manual for mine. It says 2012 on the first page but every other page I saw said 2010. Hope there's not much difference between the two years. At $16 it's a bargain if accurate. I paid Helms $200 for the paper manuals for my 2011 GM car.
Old Nov 1, 2017 | 10:21 AM
clubairth1's Avatar
Yes it's all in the manual but as you said it's a monster so it might take some time to find what you want!
Well the oil change has been discussed a bunch as it's weird.
You know it's pulled out thru a tube on top of the engine with a vacuum pump?
The filter is not a normal spin on but they have gone back to the ancient oil filter cartridge like was used back in the 50's and 60's cars.
Finally there is getting the right oil problem. The factory oil is expensive and hard to find. Since you have a 2011 and are out of warranty you can use what you want but there has been a LOT of discussions about which oils to use.
The air filters are just opened and changed but be aware that Jaguar recommends "matched" filters. Do not use any oiled cotton filters like a K&N.
Brakes are not unusual and really should not need a manual for that but I see on page 5419 brake service is listed.
Old Nov 2, 2017 | 05:34 PM
Quartzboy's Avatar
Thanks for the info! I did NOT know that the oil has to be sucked out. That's interesting. Do you know what kind of filter was/is in my '11? And are you saying that Jaguar is now recommeding to use regular spin on ones now?
Old Nov 3, 2017 | 12:45 PM
clubairth1's Avatar
Well I need to be careful because I am talking about the 5.0L V-8. Looking back I am not sure that's the engine you have?
Anyway all 5.0L Jaguar/Land Rover engines use the same oil filter I posted above.
Jaguar #C2D3670
Land Rover #LR011279
There is still a drain plug in the pan and some people have done it that way. Some under body shields need to be removed to get at the plug.
Not sure about spin on filters but maybe they are used on engines other than the 5.0L?
Old May 27, 2022 | 02:28 PM
Jaguar2022's Avatar
Default Jaguar 3.0L petrol repair manual
Got my manual from here as there was only one option for 3.0L petrol engine included all others purchased was 5.0L OR 3.0L Diesel. So who needs 3.0L Petrol here is link https://repairmanualnow.com/product-...y/cars/jaguar/
Old May 29, 2022 | 12:25 PM
leaddog11's Avatar
there are youtube videos on the procedure. Very easy. Pump is cheap on Amazon. Easiest oil change I've ever done
Old May 30, 2022 | 09:43 AM
clubairth1's Avatar
There are no spin on filters for these cars. You must use the cartridge type as came from the factory.
Old May 31, 2022 | 04:36 AM
kernt's Avatar
Yes. Easiest and cleanest oil change ever. I picked my oil extrator from Harbor Freight.
Old May 31, 2022 | 06:35 AM
leaddog11's Avatar
Old Jun 5, 2022 | 02:01 PM
leaddog11's Avatar
Great... thanks
Old Jun 10, 2022 | 09:32 AM
leaddog11's Avatar
I purchased this for our 2013 and the table of contents listing is basically useless. Hard to find anything. For example tried to find procedure for removing water pump. No where to be found. Any suggestions????
Old Jun 10, 2022 | 04:19 PM
clubairth1's Avatar
Mine is searchable? It's so big that it takes a while but that's how I mainly use it.
A the top of any PDF document under edit is a "Find" command.
I also find a ton of duplication as if they just copied the same pages over and over with every procedure?
