XJ ( X351 ) 2009 - 2019
2016 LED headlamp retrofit to earlier cars (with full functionality)
Old Mar 11, 2020 | 09:10 AM
  #221
OBC John's Avatar
Again, thanks for the reply.
I'll post the DTCs when I get a chance to plug in my iCarsoft scanner.
Since my last post above, I've been out for another drive and 'tested' some different lighting settings. And it does seem that the fault is triggered by the high beam. A simple flash brings it on.
I will ask the guy who made up the wiring connectors for those part numbers but he's working away from home for the next month so please bear with me.
Old Mar 11, 2020 | 09:25 AM
  #222
clubairth1's Avatar
Community Influencer
Interesting because the only way I can get mine to throw a fault is by turning the car off with the hi beams on and then upon restart I get the AFS error. Which is easily cleared by switching the lights back to auto and restarting the car. The only time I got the error from using my flash to pass function is when I was still blowing fuses. I started with the factory 5 amp ones then went to 7.5 amp after the 5 amp ones blew. The a short time later I went to 10 amp because the 7.5 amp ones would blow after a short time of use.
I have had the mod for a couple of years now and other than that small issue it's perfect.
Maybe double check that all 4 of the fuses mentioned above have 10 amp fuses installed?
Thank you very much for the contact info for your harness guy. I think it's of enough value to everyone that you should post it to the list but understand your position.
Old Mar 11, 2020 | 10:34 AM
  #223
OBC John's Avatar
Thanks. Yes, I replaced all the relevant fuses with 10 amp.
xDave is right of course, certain conditions are causing an out-of-parameter current in that circuit which is triggering the fault. Maybe that wire needs to be heavier (or finer) to maintain the expected resistance?
Old Mar 11, 2020 | 12:29 PM
  #224
xdave's Avatar
If my schematic was followed then the main beam 'signal' from the old wiring will activate the coil on the added main beam relay and switch the signal to the LED driver from the original 2 (when ignition is off, used for the parking lamps so not really relevant for main beam which is not requested in this state) and 14 (AFS motor supply). I have a SB540 diode with 0.5Vf ish drop across it inline in that AFS circuit to limit the current. Maybe that is not enough? For others that used the external relay method - what diodes did you use?
Old Mar 11, 2020 | 12:40 PM
  #225
OBC John's Avatar
OK, more info.
With the lights set to "off" or to "auto" and the lights are off: flash high beam and fault light is triggered.
With the lights set to on (either side or dipped): flash high beam - no fault.
High beam fully functional.
Additional strangeness: when flashing high beam, the RH high beam flickers . . . the first few times but then works fine. But OK when stalk in the high beam position.
Checked ALL fuses. OK.
Old Mar 11, 2020 | 12:54 PM
  #226
xdave's Avatar
That sounds like too much current is being drawn from original pin 14.
When the lights are are on, the current will be split between 14 (AFS) and 2 (sidelights).
Measure the resistance between both pin 14s on your adaptors and try increasing it bit a time until the warning goes away. (Both sides.) Once you have the resistance you need to add you can work out the power rating needed and splice it in at 14 source-side.
Old Mar 11, 2020 | 02:07 PM
  #227
OBC John's Avatar
Thank you, Dave.
I'm not able to do what you suggest so I'll have to wait for my guy to return from his overseas working trip. Be about a month but of course I'll report back when it's done.
Old Apr 16, 2020 | 12:04 AM
  #228
mrivers51's Avatar
Where can I get this done?
Old Apr 16, 2020 | 04:02 AM
  #229
OBC John's Avatar
Hi Mr Rivers. Can I suggest that you take 20 minutes and read through the whole thread. It will answer your question and give you an insight as to what is required.
Then if you want to go down the same route as I have, I will gladly send you the contact details of the guy in the UK who has made up the connection looms.
Old Apr 16, 2020 | 05:09 AM
  #230
OBC John's Avatar
Originally Posted by OBC John
Thank you, Dave.
Just to update where I am with this: The electrical engineer who made up the looms believes the intermittent fault and occasional high beam flicker is down to wire resistances with differnet wires taking different currents depending on the state of the lights. So, for example, if the headlights are on and the high beams are flashed, there is no issue (usually). But if the lights are off and the high beam is flashed then the adaptive headlight system fault light is triggered and the high-beam LED flickers. But again, not every time.
Anyway, he is going to make up another pair of looms using different gauge wire for a couple of the links. But as we are still in the C-19 lockdown, it's going to be a couple of weeks more, I suspect, before I can see him to test them out.
Watch this space . . .
Old Apr 16, 2020 | 06:23 AM
  #231
mrivers51's Avatar
Thanks John, is the guy Sam that I read about with the plug and play?
Old Apr 16, 2020 | 07:10 AM
  #232
OBC John's Avatar
No. I think he's the chap in London who can supply the modified LED headlights so that you can just swap them - plug-n-play.
I sourced the headlights myself and although there is an instruction within this thread on how to do the mod yourself, I didn't have the self-confidence to physically break into the (expensive) headlight units and so chose the connection loom option. A guy I knew from a previous mod then followed the instructions from this thread and made up the looms. This is the chap I can put you in touch with.
Old Apr 16, 2020 | 07:16 AM
  #233
mrivers51's Avatar
Is he in us?
Old Apr 16, 2020 | 08:54 AM
  #234
OBC John's Avatar
Is he in us?
No. UK
Old Apr 16, 2020 | 09:00 AM
  #235
mrivers51's Avatar
I'm in the US
Old Apr 16, 2020 | 11:13 AM
  #236
OBC John's Avatar
I'm in the US
He ships to the U.S.
Old Apr 16, 2020 | 11:17 AM
  #237
clubairth1's Avatar
OBC John thanks for the details about your wiring loom. I have been contacted by your guy asking for any details on my install.
I added what my car is doing to help him make modifications to the harness to eliminate the small errors I occasionally get.
Waiting to see what he comes up with.
Old Apr 16, 2020 | 11:23 AM
  #238
mrivers51's Avatar
So when he ships it will it be plug and play?
Old Apr 16, 2020 | 04:06 PM
  #239
OBC John's Avatar
Can I again suggest that you read this thread in full. The options you have are detailed herein.
Old Apr 16, 2020 | 04:17 PM
  #240
mrivers51's Avatar
Sorry, I did read it...I just don't understand that stuff
