XJ ( X351 ) 2009 - 2019
2016 LED headlamp retrofit to earlier cars (with full functionality)
Old Oct 21, 2019 | 10:30 AM
  #161
pologuy's Avatar
Anyone have a picture or video of what the 2016+ rear tail lights look like when the brake is pressed?
I have been scouring the Internet, YouTube, etc. and have not been able to find one.
I really like the look of the three "claw marks" of the 2010-2015.
Old Oct 23, 2019 | 12:39 PM
  #162
dmchao's Avatar
Drpainless, I just bought them from a random parts breaker. Elite Auto Parts had a couple 2016's in their inventory so i purchased their insurance grade lights.
Go on car-part.com and you can search nationally.
Old Oct 23, 2019 | 01:50 PM
  #163
drpainless's Avatar
Thank you for the quick reply. So there is no modifications that need to be done, I can just pick up a 2016 taillight and plug it into my 2012?
Old Oct 23, 2019 | 01:57 PM
  #164
dmchao's Avatar
Yes. Plug and play.
Old Oct 23, 2019 | 03:10 PM
  #165
drpainless's Avatar
That's great to hear. The front lights were a pain.
To install the rear lights, do I just pull back the trunk liner and unscrew the light assembly?
Old Oct 23, 2019 | 03:13 PM
  #166
dmchao's Avatar
Yes, you must remove (3 torx screws) the trunk finisher, then pull back your respective side and undo the 4 nuts. Make sure your washers don't get lost and then unclip the harness retainer (fir tree clip), then unclip the harness. Reverse to install. I'm not joking when I say it took me 20 minutes for both, going in blind. But, I started my career in industrial maintenance and repair.
Old Oct 23, 2019 | 03:23 PM
  #167
drpainless's Avatar
Thank you very much. I will get to it soon, first to track down some light units.
Old Oct 25, 2019 | 08:13 AM
  #168
NvmyJag's Avatar
2016 Rear lights
With brakes applied
Old Nov 7, 2019 | 01:29 AM
  #169
gagman66's Avatar
Old Nov 7, 2019 | 08:26 AM
  #170
clubairth1's Avatar
Community Influencer
Well I don't see any relays and it is NOT a plug and play modification?
If you plan on installing the LED's in your 2012 you MUST build the wire harness as was posted above. So that might get you the plugs
that fit into the lights but you will still need to build the relays into the correct wires.
I can't really tell from the pictures because they have the wire harness all wadded up.
See if he will lay it all out and take another picture?
Old Nov 7, 2019 | 07:18 PM
  #171
Lightspeed's Avatar
Found this while researching the conversion, for those contemplating;
2012-2018 Jaguar XJL XJ XJR X351 Xenon Standard Headlight Upgrade Replace Full LED Headlamp Adapter Harness Wires Cable
Old Nov 7, 2019 | 07:27 PM
  #172
XJsss's Avatar
Lightspeed that link didn't work for me
Old Nov 7, 2019 | 07:46 PM
  #173
Lightspeed's Avatar
weird, i checked it twice and works for me. Try searching: www.headlight-headlamp.com
I have not made any enquiries with this supplier, so it will need to be followed up on, while stating plug n play I am still curious as to any further changes to the existing electrics in pre 2016 X351 eg: relays etc.
Old Nov 7, 2019 | 10:02 PM
  #174
gagman66's Avatar
Cost is $340 with shipping. Delivery: 8-10 days. Now, if I only had a spare $2,500.00 for this project!
Old Nov 8, 2019 | 02:06 AM
  #175
Lightspeed's Avatar
I love this thread, and i will get this done with a little time, alas i am a pretty picky individual and have a great mind and ability for diy. The cracked and lowly offerings that are affordable on ebay just are not doing it for me, yeah i can make them work, but i am not really known for compromising in my wants. I am going to put this off unless i can find two j blades at a price i cannot afford to go past. So am going to go the way with my coin and spoil my new to me cat with some Mina under bonnet and exhaust options instead of the same budget just on a set of headlamps.
Old Nov 8, 2019 | 08:04 AM
  #176
clubairth1's Avatar
Lightspeed it is a great mod and I love my 2014 XJR with it but I think there are some errors in the parts your listing?
The harness you link from headlights.com has a picture of the harness;
This will NOT work! Again you must build your harness with 3 additional relays for each light to make it work.
The other method is to keep the stock plugs and wiring and internally modified the LED lights.
But your link implies all you need is this harness and a pair of stock LED headlights.
I think you should verify that this will work before you spend any money. At least have a money back guarantee if it does not work.
Old Nov 8, 2019 | 09:41 PM
  #177
pologuy's Avatar
Originally Posted by NvmyJag
2016 Rear lights
With brakes applied
So no more three claw marks...
Old Nov 20, 2019 | 05:38 PM
  #178
Stanley Geneus's Avatar
Hey I got a 2013 Jaguagr XJL in Atlanta GA. Can you provide the installation service of retrofitting the lights if I purchase them?
Old Nov 20, 2019 | 06:05 PM
  #179
gagman66's Avatar
Me too, for the front headlights. The rear appears to be straight forward....
Old Dec 16, 2019 | 06:01 PM
  #180
zYx's Avatar
zYx
Talking
This is amazing.
couple of questions:
1. Do I need to remove the bumper? (I can’t seem to find info about this)
2. What’s the best place to buy genuine headlights? I can only find the right side on eBay. Can I buy a set of two somewhere else?
I’ll be following method two once I get the car 🤪
