XJ ( X351 ) 2009 - 2019
2018-2019 Common issues?
Old Aug 2, 2024 | 12:00 PM
Paldi's Avatar
Default 2018-2019 Common issues?
Four months ago I purchased a 2019 XJL Portofino "petrol" 3.0 V6 with 18k miles. I'm wondering if Jaguar got all the bugs out of the later year XJs? Have any owners had issues? What should I look out for? So far I had to replace the coolant tank/level sensor and the backup camera, both under warranty, but the warranty ends in January 2025. It has 21,000 miles now. Thanks
Old Aug 2, 2024 | 03:11 PM
cbarr's Avatar
The plastic coolant pipes are still a weak spot on late XJs. Replaced them on my XJ (2018) at 68k miles when one was starting to weep. Not a cheap job since access needed under supercharger. Lots of threads on here (and the F-type section) about the coolant pipes.
Old Aug 2, 2024 | 10:18 PM
Paldi's Avatar
Would that be a warranty item?
Old Aug 2, 2024 | 10:25 PM
OzXFR's Avatar
Not unless/until a pipe fails and leaks (while still under warranty).
Preventative maintenance such as upgrading the coolant pipers to the metal versions (before any failures/leaks) is not covered under warranty.
Old Aug 3, 2024 | 09:07 AM
Paldi's Avatar
Jaguar knew about this issue for years. Can't believe they didn't fix it or issue a recall.
Tiggernlizzy
Oct 19, 2023 03:00 PM
JazzyJ
F-Pace (X761) / C-X17
16
Aug 31, 2020 08:35 PM
Mark SF
Jan 7, 2020 12:26 PM
maxiedaniels
Jun 29, 2019 06:46 PM
DonJ
Oct 5, 2018 07:27 PM
