XJ ( X351 ) 2009 - 2019
4 year old XJL sunroof leaking
Old Aug 11, 2019 | 07:46 AM
Andyb123's Avatar
Default 4 year old XJL sunroof leaking
Hi All,
My 4 year old XJL has starting leaking around the light cluster in the front and also from the sunroof control switches, I suspect the sunroof seal has or is failing allowing water ingress. Has anyone else had this problem, also how easy is it to replace the rubber seals around the sunroof.
Need to speak to my local dealer about the problem, not sure if this will be covered by the extended warranty I have on the car.
Regards,
Andy
Old Aug 11, 2019 | 08:52 AM
clubairth1's Avatar
Community Influencer
You might also have the moon roof drains plugged. Do you park under trees?
Old Aug 11, 2019 | 09:16 AM
mikebaker3's Avatar
I agree with clubairth1. Start by retracting the moonroof/sunroof and look at the drain pan at both front corners. I just went through a similar problem with my 2006 X350 and guidance in that forum recommended running a piece of weed whacker line down the drain tube. If the tubes are clogged, the water collecting in the pan will spill over.
Check the drains first. Doing so is no cost.
Old Aug 11, 2019 | 12:54 PM
Andyb123's Avatar
Hi sorry for the slow repay, the drains were cleaned at my recent service two weeks back and no I stay clear of trees as often as I can thanks,
regards,
Andy
Old Aug 11, 2019 | 12:55 PM
Andyb123's Avatar
I will try that, by the way what is a weed whacker and were would I get one.
Cheers,
Andy
Old Aug 11, 2019 | 02:54 PM
mikebaker3's Avatar
Weed Whackers are in the States to trim the grass along sidewalks, etc. They use a nylon line on a spool to actually cut grass and is spun by a motor. The nylon line is what cuts the grass. Some are gas powered, some are electric with a cord and now they come battery powered. Here in the states, we buy them at home improvement stores such as Lowes and Home Depot and at Walmart.
Old Aug 21, 2019 | 05:30 AM
Andyb123's Avatar
Default Weed whacker
Thanks all for the replies have been away in Spain for the last 7 days so not able to get at pc, in respect of my last question what is a weed whacker - we call this device a 'Strimmer' here in the UK, once I read the description I knew immediately what you guys are talking about. I have one and a spare coil of the nylon wire and so will check for myself the drain pipes are clear.
Thanks to all who replied to my question , the help is very much appreciated.
Regards,
Andy
doriel
Feb 1, 2022 01:58 AM
xj8vdp
Jun 8, 2017 04:32 AM
gtjoey
39
Aug 30, 2016 06:02 PM
Pilotman11
Nov 11, 2015 07:54 AM
weisberg
Jan 1, 2014 11:51 AM
