XJ ( X351 ) 2009 - 2019
5.0 Injector removal
Old Jun 18, 2022 | 01:22 PM
Sec-Jag's Avatar
Default 5.0 Injector removal
evening all, so long story short i need to remove my rocker covers, to do so i need injectors out, however 3 were very stuck in, 2 have now snapped inside the Head and one is still sat there, any suggestions to get them out? this is an engine i have out of the vehicle, i even lifted the whole engine from one of the injectors and it didnt budge, really seized in there.
Old Jun 18, 2022 | 04:12 PM
NBCat's Avatar
You can try spraying a penetrating lubricant around the nozzles and allow them to soak for 24 to 48 hours before attempting to remove them. I have seen some injectors take more than 130 strokes from the special tool slide hammer before coming free.
I personally haven't experienced a situation with an injector snapping before coming out of the head.. I would suggest contacting a Jaguar main dealer or local specialist for advice on removing a broken injector that's still in situ.
Old Jun 26, 2022 | 07:14 PM
clubairth1's Avatar
Community Influencer
It takes a slide hammer type tool to remove them. Did you use that?
You can't just pull on them you need that impact to get them moving.
It has also been reported that the injectors most of the time are stuck in there pretty tight. Plan on 50 to 100 hits on the slide hammer tool to get them out.
Here is the injector. Can you tell us where it broke?
Here is the proper tool;
The non-Jaguar tool is about $55 on Amazon.
Fuel Injector Removal Tool Fuel Injector Removal Tool
Old Jul 2, 2022 | 08:43 AM
silvertonesx24's Avatar
My car with 60k miles had no problem removing the injectors on Bank 1. 2 of them came out with the fuel rail. The others only took a few hits. You definitely need the tool though. You can get a clone tool for $30 IIRC
NevadaXK8
Jul 29, 2025 12:59 PM
2011_XF_5.0
May 16, 2022 08:56 PM
XJR_hunter
Feb 20, 2022 11:25 AM
JezuzNoChill
Jan 19, 2022 03:58 AM
Sean Mc
Jan 12, 2020 03:34 PM
