XJ ( X351 ) 2009 - 2019
Affraid that the engine is dead and gone! XJ-L 5.0L V8
Old Jan 23, 2022 | 11:38 AM
Lyktestolpe's Avatar
Default Affraid that the engine is dead and gone! XJ-L 5.0L V8
Hello,
Earlier today I was driving to a friend of mine, when I passed a slow-driving car. I started to hear some weird noise, only when the accelerator was pushed around 5-10%. Fast ratteling sound.
10 minutes later I arrived my destination and shoot the video. I decided to call for road assistance and get it to a workshop as soon as possible. It took about 2-3 hours until the assistance arrived. When I started the car, it was barely staring with a much worse metal ratteling sound, some times almost howling.
It's currently delivered at a local workshop. I'm worried that the engine is basically dead and gone.
Does this sound like a typically recognizable type of problem?
Here is two videos of the sounds:
Old Jan 23, 2022 | 03:31 PM
Thermo's Avatar
Veteran: Navy
To me, that soudns like a broken connecting rod which would be pretty much fatal for the engine. Granted, I would also suspect a check engine light on that cylinder saying that the cylinder is running rich/misfiring. So, I could be way off. I would say see what the shop says and go from there. I guess it could also be a broken valve spring and what you are hearing is the cylinder hitting the valve and pushing it back up into its hole. But, I would think that again, you would be getting an error code and something like that normally doesn't last long before something gets bent/stuck.
Old Jan 23, 2022 | 06:29 PM
tjankovs's Avatar
Sounds like you spun a bearing.
Old Jan 23, 2022 | 08:18 PM
Mark SF's Avatar
Particularly symptomatic of a shell bearing failure is that combination of a squeak, and a knock. It most definitely sounds like a main bearing, big end, or small end.
How old is that car and how many miles? Service history?
Old Jan 24, 2022 | 12:09 AM
It’s from 2011. 116 000km. All services is done.
Old Jan 24, 2022 | 10:19 AM
Mark SF's Avatar
Well, that sucks.
CRS 123
Apr 17, 2017 12:11 PM
John Vega
Jun 5, 2016 06:11 PM
Mrhenderson702
Jan 17, 2015 06:22 PM
doughball2014
Nov 5, 2014 05:04 PM
catman200
Sep 11, 2014 09:14 AM
