XJ ( X351 ) 2009 - 2019
Any way to lock the Doors while Engine is running?
Old Jan 24, 2014 | 10:29 PM
aceeg's Avatar
Default Any way to lock the Doors while Engine is running?
The keyless ignition is a waste . You can't even lock the doors and warm up the car in this frigid 0 deg temperatures.
My Caddy had remote start heated seats car doors locked, and if someone jumped in the car the engine would stop if you put foot on gas or brakes.
Why can't the eoro cars do this?
Thieves can steal your car if it is running without the key fob. That is wrong it should shut the car when it doesn't recognize the key fob.
if you leave it running someone can jump in steal ur car take off they just can't restart it .
Old Jan 25, 2014 | 08:07 AM
amcdonal86's Avatar
Be careful what you wish for. A lot of times in my XKR, I have "ket not detected" warnings. Thank goodness the car doesn't shut down every time that happens!
Old Jan 30, 2014 | 12:14 PM
derrickonline's Avatar
You're in NJ, amc is in Alrington, VA, and I'm in MD. Clearly we're all in the cold areas! I actually have an Audi Q7 4.2L which doesn't have remote start, but does have push button start.
I can get out of the truck, then flip the key blade out to manually lock the door. That works.
I tried something similar this morning in fact with the Jag. Didn't see a "key hole" but it was so cold I wasn't exactly looking hard. I did hit the button on the door, horn beeped twice but didn't lock. I think the beeping is to say "hey idiot you left the car running".
I'm not seeing this as a possibility. Last two shops I talked to about remote start said they wouldn't touch it. I'd much rather them say that then "f" something up. Same with the Audi most shops don't want to touch it.
My benz on the other hand, shops would do it, but for $1500 I didn't see the value since I trade these things in so frequently.
Our Camry! Done in 2 hours. Under $250! lol.
Old Jan 30, 2014 | 06:09 PM
Jffcurt's Avatar
I'm surprised you still have a Jag as much as you've belly ached about them the last three years.....
Old Feb 1, 2014 | 08:38 PM
aceeg's Avatar
me too!
Old Jul 14, 2014 | 07:48 AM
KingFala's Avatar
Default Locking car with engine running
My issue is a hot weather one. Traveling with a dog often requires keeping the A/C going while stopped for lunch or some other brief chore. So far I haven't found the solution either. Although the car will continue to run without the fob nearby, I can't figure out how to lock it.
Luck
King Fala
Old Aug 15, 2014 | 03:43 PM
Effbee's Avatar
Luck
King Fala
Dog left in car, engine running with car locked, even if you could, wrong on so many levels.
Old Aug 15, 2014 | 08:07 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
Good way to get the windows broken in "rescuing" the dog.
Also with broken window, car can also be stolen...
NOT a good idea..
BrentGardner
29
Dec 16, 2024 12:13 AM
msdg137
Sep 16, 2015 06:24 AM
Thia
Sep 1, 2015 10:36 AM
cheaperts
Aug 30, 2015 06:48 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
