XJ ( X351 ) 2009 - 2019
Audio/Video Inactive
Old May 16, 2017 | 04:58 AM
Serlock's Avatar
Default Audio/Video Inactive
Hello, this morning i had to jump start my car. After doing it i found that audio video section is inactive, also backup camera doesnt show anything, also when i lock the car mirrors wont fold. I suspected that some fuse has blown, but i checked all of them TWICE. In the boot, in the interior and under the hood. All fuses are good. I guess it must be some infotainment block faulty. Any ideas?
Old May 16, 2017 | 09:22 AM
XJsss's Avatar
Try locking the car from outside by double clicking the button in the door handle and hearing a chirp. Let the car stand for a minute and then open the door. This should reset *** many of the electrical components.
Old May 16, 2017 | 09:40 AM
Serlock's Avatar
Default Re
This is what i see, double locking did not help, ://
Serlock's Avatar
Navigation also doesnt work
Old May 16, 2017 | 11:12 AM
Serlock's Avatar
Maybe there are some amplifiers or navigation units somehwere in the trunk? i have a friend with the same car i can exchange and check if its working or not.
Old May 16, 2017 | 01:15 PM
Serlock's Avatar
Please guys, dont force me into going to a s.teaalership :P it might be an interior control module, just guessing, or a bluetooth-sat nav module..
Old Mar 1, 2019 | 08:07 PM
pedroquintero's Avatar
Dying to know how you went about fixing this. Please help! Thank you much!!!
Old Mar 2, 2019 | 01:23 PM
clubairth1's Avatar
Community Influencer
I would try a new battery next. Do you know why your old one went flat?
Maybe it's time for a replacement?
Old Mar 3, 2019 | 08:40 PM
Stuart S's Avatar
If it still has the original battery, it's way past time for replacement. Serlock's Personal Profile shows that he has a 2011 XJ. Make sure to get the proper AGM battery.
Old Mar 8, 2019 | 03:54 PM
Geoffrey Fake's Avatar
are you in VALET mode?
otherwise, between the rest arm on the back seat, you have a big fuse box. maybe check if it is all OK.
if nothing bad, Disconnect the battery in the trunk, wait a few minutes ( important) and reconnect the battery, all should reset. ( don't close the trunk door while battery disconnected )
