XJ ( X351 ) 2009 - 2019
Best place for parts?
Old Oct 31, 2017 | 01:27 PM
Quartzboy's Avatar
Default Best place for parts?
Hello fellow Jag lovers,
Can anyone recommend a good place online that sells Jaguar parts? Specifically for newer models as I have a 2011 XJL V8 N/A.
Car is at the dealer who wants to charge some "interesting" prices for what I suspect and not expensive typical maintenance parts (air filter/oil filter, etc etc.).
Much obliged!
Old Oct 31, 2017 | 02:15 PM
Thermo's Avatar
Veteran: Navy
I would start with e-bay. You can find Jaguar branded parts there for fairly cheap. For example, the oil filter at where you are talking about is probably asking in the $70-85 range. On e-bay, you can normally find the same filter (Jaguar logo and the Jaguar part number on the box) for around $18 a filter (granted, you will most likely need to buy 6 of them at a time). But, for the price of 1 of theirs, you can get 5 of these.
Not saying that you are going to find this sort of price break on every part, but with some looking, you can find some pretty good deals. Otherwise, I would be looking at either OEM Jaguar, Land Rover and BMW Rplacement Parts (dealership out of Cleveland Ohio which I have used and have had good luck with them, just have to do it all via the web, calling them will get you the normal list price) or Gaudin Jaguar/Porsche (JPLV) of Las Vegas. You tell them on the phone that you are a member here, they will get you a good price.
Old Oct 31, 2017 | 10:41 PM
OzXFR's Avatar
I have bought a few parts for my F-Type, mainly brake parts, and after a lot of searching on eBay and elsewhere I found the cheapest prices were usually at Britcar (in the UK).
Great service and reasonable shipping cost as well.
See here: XJ 2010 on | Jaguar | Shop for Parts | Britcar (UK) Ltd
It helps a lot if you know the part number and search under that, otherwise you may struggle to find the part you are after on their website.
Old Nov 1, 2017 | 07:54 AM
hafren's Avatar
I've used https://www.jaguarlandroverrenoparts...-v8-gas-engine and the parts manager is very helpful.
Old Nov 1, 2017 | 11:38 AM
NvmyJag's Avatar
I've bought a lot of parts in the last year and found
Jaguar Land Rover Columbia to either have the best price or willing to match price plus they are in SC so shipping to NC is two days or less.
You have to make your purchase online to receive the best price.
https://www.oemdiscountcarparts.com/
Old Nov 11, 2017 | 06:11 PM
thomash85715's Avatar
What happened to gaudin in las vegas? They seem to have morphed into porsche and ford but no jaguar any more? Used to be I could start a search on their site and pull up a diagram and figure out what I needed and buy it cheaper than local dealer. Am I doing something wrong? I have some bad hoses in my intake path causing lean codes but cannot search if I don't know the exact name or original part number. Thank you.
Old Nov 11, 2017 | 06:27 PM
OzXFR's Avatar
I use JLR Reno Parts, works a treat, see here for example (change year, model, sub-model etc as necessary): https://www.jaguarlandroverrenoparts...-v6-gas-engine
I don't buy from them as they don't ship to Oz, but I use their site to find the part number I am after.
Old Nov 11, 2017 | 08:37 PM
hafren's Avatar
+1 Same as my recommendation post #4. If you need help speak with Bret Robards Parts Manager
Old Nov 15, 2017 | 08:32 AM
Polyesterpig's Avatar
Jaguar Land Rover Reno parts. Can’t beat them.
Old Nov 20, 2017 | 05:29 AM
Paulc732's Avatar
I use jaguarparts.com print off there price and my dealer in Harrisburg PA will price match for me.
But i did get my pads and rotors off ebay very happy with them even came with 2 new sensors.
Old Nov 21, 2017 | 08:35 PM
A fitted semi-hard hose from the PCV on right bank to the throttle body casting was leaking. Dealer here in tucson wanted $64. Reno gets $49 plus shipping so I came out a bit ahead. I had never seen the texas guys so will try them too. Thank you.
