XJ ( X351 ) 2009 - 2019
Broken 2011xjl
Old Mar 15, 2025 | 02:54 PM
Echapo414's Avatar
Default Broken 2011xjl
Just bought 2011 jaguar xjl battery fault on low coolant fault gear box fault,suspension all way to ground . Help
Old Mar 15, 2025 | 03:53 PM
NBCat's Avatar
Use a voltmeter to determine the available voltage across the battery terminals with the ignition in the OFF position for at least thirty minutes. There should be a minimum of 12.6 volts available. If not, try charging the battery for five hours at 2 to 5 amps and retest. If the voltmeter still shows less than 12.6 volts, the battery must be replaced.
Many random DTCs and instrument cluster warnings are the result of a failing or weak battery.
Old Mar 16, 2025 | 09:44 AM
Baltobernie's Avatar
Was the car healthy when you bought it?
Raypolley68
Jul 29, 2024 11:35 AM
theoriginalbabu
Jul 11, 2024 10:10 AM
Loxmth
Dec 31, 2015 05:07 AM
Bama Jag
Jan 31, 2012 04:51 AM
