XJ ( X351 ) 2009 - 2019
Can I use Autosol Chrome Polish on these areas on the XJ?
Old Feb 25, 2015 | 03:02 PM
apachegogo's Avatar
Default Can I use Autosol Chrome Polish on these areas on the XJ?
Can I use Autosol Chrome Polish on these areas highlighted with a red arrow? I guess my question is, are these areas all metal/chrome?
If its plastic could it get damaged?
Old Feb 27, 2015 | 07:11 AM
apachegogo's Avatar
Anyone?
Are these areas all metal/chrome? Or plastic?
Old Feb 27, 2015 | 10:47 PM
jaglover123's Avatar
Yes you can. For the mirror finished trim, you can polish away. For the matte ones like around the windows just do it in moderation.
Old Feb 28, 2015 | 03:33 AM
apachegogo's Avatar
THanks!
Old Feb 28, 2015 | 03:57 AM
OzXFR's Avatar
The "chrome" window trims on the XF are in fact anodised aluminium, and I suspect they are the same for the XJ.
These trims commonly suffer from a tarnished look, mine does, and nothing but nothing I have tried makes any difference, including Autosol Chrome Polish, Autosol Metal Polish and Autosol Anodised Aluminium Polish.
Old Feb 28, 2015 | 05:30 AM
Gippsland's Avatar
The bigger problem will be getting those red arrows off the duco.
Old Mar 1, 2015 | 04:14 AM
apachegogo's Avatar
lols yeh
Old Mar 1, 2015 | 02:14 PM
Fraser Mitchell's Avatar
Most "chrome" on cars these days is covered with a layer of clear plastic. So polishing with Autosol doesn't touch the metal at all. On some parts, over time, damp creeps behind the clear plastic and dulls the shine. However use of metal polish is ineffective because of this plastic layer. There really isn't a lot one can do about this.
Certain parts can be anodised aluminium, but are sometimes stainless steel. These are normally not covered with a plastic layer.
I have a tube of Autosol in the garage, but find I mainly use it on my MG Midget, which still has a lot of traditional chrome-plated Mazak parts.
The only test is to try a bit of Autosol on the part and see if it does anything at all. If it doesn't you have that plastic layer. Virtually all anodised aluminium is a matt finish as the anodising is done using an electrolyte bath and electricity. It's a reverse of plating, basically.
Poet
Feb 7, 2025 02:18 PM
hoodun
Nov 20, 2022 02:35 PM
diablomkii
Sep 27, 2015 07:56 PM
PinnacleWax
Detailing / Car care
Sep 25, 2015 12:46 PM
ahunt4
Sep 25, 2015 03:43 AM
