XJ ( X351 ) 2009 - 2019
Car shakes at 55-60mph
Old May 20, 2020 | 03:59 PM
Chris32111's Avatar
how so you know if i have air shocks or regular shocks.. i have a 2011 XJL
Old May 20, 2020 | 04:02 PM
XJ8JR's Avatar
All X351 XJs have regular shocks/springs up front and air shocks in the rear.
Old May 20, 2020 | 04:23 PM
XJsss's Avatar
All 4 shocks are "valve a-tronic" (i.e. electrically controlled valves from soft to firm) and the rears have in addition an air adjustable bladder to control the ride height..
Old May 20, 2020 | 05:02 PM
ricardoa1's Avatar
Are they not Magnetic?
Old May 20, 2020 | 05:39 PM
XJsss's Avatar
Nope adjustable valving: https://www.dscsport.com/2018/05/10/...ptronics-work/ and I misnamed it its Damptronic
Old May 21, 2020 | 05:37 AM
Thermo's Avatar
Veteran: Navy
Magtronic shocks simply apply current to a coil and this puts a magnetic field into the shock which causes the fluid in the show to get thick. The stronger the current, the stronger the magnetic field, the thicker the fluid gets. The thicker the fluid, the shorter distance the shock can move over a period of time. The Damptronic shocks work on a similar principle except that the fluid has to go through a valve. This valve can be full open (maximum comfort), essentially fully closed (very firm, very little fluid passes), or some point inbetween. If you have a problem with the suspension, the computer removes any signal to the shocks and this causes the electronic valve to go full shut (maximum firmness).
VancouverXJ6
May 29, 2018 12:17 PM
orangeblossom
Apr 30, 2016 02:51 AM
desertchimera
21
Apr 24, 2014 09:37 AM
WaterDragon
Aug 5, 2013 01:03 PM
princemarko
Mar 21, 2010 12:11 PM
