XJ ( X351 ) 2009 - 2019
Centre seat button
Old May 16, 2018 | 03:29 PM
bjolly's Avatar
Default Centre seat button
Hi,
The seat button next to the dual screen button on the centre consul does not appear to do anything is that correct or is it a unique feature of my car?
Old May 17, 2018 | 08:54 AM
xdave's Avatar
It is meant to open the seat options window on the main touch screen, which lets you seat the heating levels for the front seats, and if fitted the cooling level and massage options.
On a 2012 you should be able to get into the same menu by pressing one of the seat pictures on the home screen with the climate widget visible. If that works, but the button doesn't, then maybe the AC control panel is faulty. If that also doesn't work, then something else may be wrong. Did Jag offer the X351 without any heated seat option? Maybe the control panel as been replaced at some point.
Old May 17, 2018 | 02:25 PM
bjolly's Avatar
Thanks xdave,
all other functions for the seats work through the touch panel but not just that button. Is it easy to replace the switch ?
Old May 17, 2018 | 05:25 PM
xdave's Avatar
It is easy, yes, there are only four screws after you pry the screen surround off (use a plastic tool to lift it where the leather dash has a seam half way up, and then pull it forward).
You would need to replace the entire AC control panel as it is one assembly.
Note you can open it up easily enough to see if the it is a mechanical failure that could be repaired. There are various little plastic spacers in there for each switch and I suppose the one for that switch may have broken so could be swapped with one from a lesser used switch. Otherwise match one up on ebay by searching for the WERS code that is on your current panel (something like CW93-18C858-BE for a 2012, but the revision depends on your vehicle spec so do check before buying).
New they are about £500, used about £50.
danbvm
Dec 30, 2017 01:36 PM
Philipintexas
Nov 4, 2016 09:28 AM
looops
Oct 3, 2014 03:24 PM
