XJ ( X351 ) 2009 - 2019
Changing starter on 2011 XJ NA
Old May 5, 2022 | 11:46 AM
apllrd's Avatar
Default Changing starter on 2011 XJ NA
Hi all, I'm getting a click but no crank issue that seems to be a common thing with these cars. I have changed the battery and tried to start with jumper cables attatched from another running vehicle, I'm about to check relay but with the click, my thought is the starter itself.
Has anyone here changed one by thereselves? I had a look but no specfic guide or video seems to exist showing the location and removal procedure.
Any hints, tips and general advice will be welcome, thanks.
Old May 5, 2022 | 12:13 PM
clubairth1's Avatar
Community Influencer
It's not common at all? Do some searches very little starter problems posted.
If it was common there would be repair videos and forum postings on how to do the repair. Your not finding that.
What does that tell you?
Old May 5, 2022 | 12:19 PM
apllrd's Avatar
The click no crank is common. i'm trying to get a head start on every scenario, the starter going bad on a 2011 car is probably the most mechanically invasive I can think of at the moment.. I've seen this problem before on Ford cars, caused by incorrect flywheel ring material wearing down and the resulting dust being attracted by the magnets in the starter and seizing it up. That was on a much younger car. my experience tells me it is a possibility, that's why I posted , to get feedback on others experience.
Old May 5, 2022 | 03:18 PM
apllrd's Avatar
Update, Diagrams where unhelpful so empied the trunk and traced the biggest wire. Goes to a distribution strip on the inside lip of the trunk and the biggest wire coming from that was via an open circuit mega 200A fuse. I'm guessing it's going to the starter as it's the biggest wire, but the electrical diagram shows a 400A?
Also there is a low ohm reading to ground despite the ignition off and battery disconnected. I can only guess that the solenoid isn't releasing on engine start which, as it's tied electrically to the generator/alternator, it could be the root cause of the other electrical issues. I have a new starter ordered along with an alternator. Gonna replace that fuse and see how it goes from there.
Old May 1, 2024 | 06:29 PM
Kavinp's Avatar
Default Jaguar xjl
hello I was wondering if you go through with changing your starter on your jaguar? If so i it fix the problem that you was having
Coventrywood
Sep 26, 2021 05:29 AM
Starcaster
Jan 27, 2021 06:02 AM
SteveXJ8L
Jan 2, 2020 08:52 PM
evildrome
Aug 13, 2018 10:28 AM
dinerdash
May 15, 2013 07:30 PM
