XJ ( X351 ) 2009 - 2019
check engine light
Old May 10, 2020 | 03:36 PM
2859bar's Avatar
Default check engine light
2014 XJR
first service in 1500 miles warning came on.
then about 500 miles later brake pads worn light came on.
now engine light is on.
what is going on?
Old May 10, 2020 | 05:00 PM
ricardoa1's Avatar
Originally Posted by 2859bar
2014 XJR
what is going on?
pull the engine code.
Old May 10, 2020 | 05:11 PM
wombat's Avatar
1. Your car is due a service. The 1500 mile warning is there so you can book it in for service in a timely fashion.
2. Your brakes are worn out.
3. Without the code we have no idea.
wombat
Old May 11, 2020 | 07:10 AM
Thermo's Avatar
Veteran: Navy
2859Bar, like wombat said, the service light is just telling you that you need to schedule the car for some sort of service (annual check up, oil change, etc). Unfortunately, without a special scanner, you are not able to reset the service message yourself.
As for the brake wear warning message, there are sensors in the brake pads that warn you when the pads are getting too thin. If you did your own pad change, did you replace the sensors too? In short, the sensor is nothing more than a thin wire that is exposed that when the pads wear to a point, this wire touches the rotor and grounds the signal. if you don't do the pads immediately, then you can wear this wire through and this causes the brake pad wear warning to remain in. The only way to clear this message is to put on new pads and also change out this sensor. Replacing the sensor is easy and is like a $15 part at your local auto parts store. You don't have to buy the jaguar specific one. This is a universal sensor. Get one with the correct plug on the end and you are good. Of note, there are 2 of these sensors on the car. One on the front, one on the rear. I don't recall which corners they are on. I want to say left front and right rear.
As for the engine error message, like was said, we need more info. Your local auto parts store can read the engine codes and that will give us a starting point. It can be a number of things.
Overkill
May 18, 2020 05:49 AM
MrHill
Feb 20, 2017 08:15 PM
ek993
Oct 24, 2014 07:34 AM
XK8Guy
Apr 16, 2008 11:51 AM
