XJ ( X351 ) 2009 - 2019
Clunk when going into drive or reverse very intermittent
Old Aug 14, 2015 | 07:58 AM
derrickonline's Avatar
Default Clunk when going into drive or reverse very intermittent
All:
Anyone get a "clunk" noise going into drive or reverse intermittently. It's like nails on a chalk board for me to hear it. Yet every time I mention it to my dealer the response is "it has a lot of moving parts, it's not uncommon". It worries me however.
By the way I always come to a complete stop when shifting. Come to think of it...it tends to happen not while say doing a 3 point turn or parallel parking but that initial start-up, and reverse, or start-up and forward. Very intermittent which is bothering me.
Is this normal? Anyone else?
Old Aug 14, 2015 | 04:26 PM
tbird6's Avatar
What car details?
Year, Engine, Transmission...
Old Aug 15, 2015 | 09:10 AM
2011 xjl v8
Old Aug 15, 2015 | 11:00 AM
spegor's Avatar
My xkr 2010, used ti do that clunk, in reverse in movement, now my xj 2015 do the same noise only more low. I think its because of the brake pads very large in the 20 inches , so the pads move with the reverse
Old Aug 17, 2015 | 05:11 AM
haz783's Avatar
Originally Posted by derrickonline
All:
Hi Derrick
Think i know the "clunk" you're talking about, happens to me from time to time.
I only experience it when i had parked and didn't pull the park brake on BEFORE either taking my foot off the brake or switching the dial to park, oh and also happens when i parked downhill.
So basically from now on,
I stop, pull park brake, turn from D to P, then take my foot off the brake.
Hope that helps
Old Aug 26, 2015 | 04:19 PM
Delta-V's Avatar
Happens on my 2011 XJL V8. This is my first automatic in 21 years of driving, so I figured it was normal driveline slack.
I'll try your trick and see if it works, haz783.
Old Aug 27, 2015 | 07:17 AM
That might explain why it's so intermittent. I'm going to give that a try as well. Thanks for the feedback. I was worried it was the tranny.
Old Sep 16, 2015 | 02:00 AM
Wolfy's Avatar
2 weeks ago, I heard a big 'CLUNK' when put in reverse after the car was parked for 3 weeks. It drove fine after that. It's disconcerting but appears to be normal. Mechanically, I have no idea what was going on, maybe those of you gearheads can explain.
Old Sep 17, 2015 | 01:33 PM
XJ8JR's Avatar
I had this issue on a 2005 X350. A transmission fluid flush and refill cured it.
Old Sep 21, 2015 | 05:34 AM
Goncalo Proenca's Avatar
Today when I was parking I remembered this thread.
I turned off the radio and had the roof open, when I entered the garage and put the car in reverse - it made a "click" ( soft, but audible ).
Was a tight spot, had to use 3 or 4 times reverse, but it only did the "click" once.
Go figure
Forcedair1
Sep 8, 2025 01:57 PM
tberg
Sep 7, 2015 07:32 AM
Xkr x100
Sep 6, 2015 08:50 AM
XJsc-guy
Sep 2, 2015 11:43 AM
