XJ ( X351 ) 2009 - 2019
Code P2189
Old Apr 5, 2022 | 07:23 AM
2859bar's Avatar
Default Code P2189
Well not exactly sure what’s going on with my 2016 jaguar XJR. Vacuum hose was broken and repaired and then the same day later on in the evening after being driving it notice the car is idling high. Got home turned it off came outside couple hours later and the engines bouncing up and down and idling really rough almost like a rod knock. Put the code reader on it and notice a code P2189. I guess these are pretty common. Is it an easy fix or does it need to go to the dealer? Anybody can help?
Old Apr 5, 2022 | 09:45 AM
XJ8JR's Avatar
You’ve still got a vacuum leak somewhere on that bank.
Old Apr 5, 2022 | 09:56 AM
2859bar's Avatar
do you think its a pvc cap? that what its showing in the code reader. P2189. Funny thing is no brake light when brake pedal was hard and now no check engine light on this one either. whats going on? you think its a vacume leak?
Old Apr 5, 2022 | 11:45 AM
ChaosphereIX's Avatar
Take it to a mechanic. Get it fixed properly without the guesswork.
Old Apr 5, 2022 | 05:00 PM
XJ8JR's Avatar
I had a bad vacuum leak a year or so ago. It turned out to be my fault; I deleted the symposer unit and didn't properly plug up the port on the intake manifold. I tried the cigar smoke air leak test several times and got nothing. I put new orings on the big vacuum hoses and replaced the PCV caps, with no dice. I finally gave up and took it to a local shop who used a real pressurized smoke machine to find the problem. Point is, be prepared for the possibility of spending a lot of time chasing your tail trying to find the leak or just find a good pro to handle it.
jameson
Aug 28, 2024 10:08 AM
Jon89
Jan 29, 2019 11:44 AM
Wewillbfree
XJ40 ( XJ81 )
Apr 25, 2017 06:22 AM
Spikepaga
Dec 4, 2014 01:34 AM
meeburtxk8
Nov 16, 2012 02:29 PM
