XJ ( X351 ) 2009 - 2019
Coolant Leak
Old Aug 1, 2021 | 04:20 PM
Daneel227's Avatar
Default Coolant Leak
During multi-point inspection, while my car (2014 XJL Portfolio, 41,059 miles) was on the hoist, a coolant system leak was discerned, requiring immediate attention. Yet I have seen no discernable signs one would expect from a coolant leak. Temp gauge stays in normal range, no leaks on garage floor or driveway, no discernable drop in fuel efficiency, etc.
Dealership repair advised: 1 - pipe-outlet; 1 - tube; 1 - pipe heater; 2 - gasket; 1- gasket-indctn ma; 2 - BG coolant. Cost: $1679.88, parts and labor. Why none of the signs of a coolant leak issue?
Old Aug 1, 2021 | 05:14 PM
NBCat's Avatar
Bear in mind the engine and gearbox are covered with an undertray that traps any fluid leaks from dripping onto the ground. The best method to discover any coolant leaks is by using a pressure tester when the vehicle has been cold-soaked, preferably overnight. Use the tester to pressurise the cooling system to 1 bar and check for leaks if the gauge begins to drop below 1 bar.
There are several places that can cause a coolant leak on the AJ133/AJ126:
  • Water outlet pipe under the supercharger
  • Heater pipe connecting backs of both cylinder heads
  • Thermostat housing
The plastic materials these parts are made from can withstand a finite number of cold to hot to cold cycles before failing. Failure of the water outlet or heater pipe can result in catastrophic engine damage within a minute or so. The design of the water outlet pipe has been changed with the superseded part not having a seam joining the two sides.
Old Aug 2, 2021 | 09:29 AM
Daneel227's Avatar
Thanks for the info; appreciate the pithy yet comprehensive reply; the car is at the dealership as I type this. The way this Service Advisor explained I fully understood. He stated it was a slow leak coming from on top of the engine and that as the leak comes out, when the engine is hot and the leak runs down the side it dissipates before it hits the ground due to engine heat. He said this is why a leak of this natrure is so insidious. You will not know you had a problem until the car starts running hot and lights "light up" on the dashboard and just as you described, this could portend possible catastrophic engine damage shortly thereafter. "Whew!!"
Old Aug 2, 2021 | 01:56 PM
XJsss's Avatar
In my experience I NEVER would let the engine overheat as before that I would get "coolant low" warnings and then would either top up if close to the dealer or call AAA to flat bed to the dealer. Once had the issue in Charlotte NC and had the XJ transported by Jaguar / AAA to my local dealer in Roswell GA @ 250 miles.
Old Aug 3, 2021 | 01:23 PM
clubairth1's Avatar
Community Influencer
Is the car using any coolant?
But yes be sure and change the water pump as well as any plastic piping.
Old Aug 4, 2021 | 02:01 PM
Daneel227's Avatar
The vehicle never overheated (none of my vehicles have ever overheated). The coolant leak was discerned during a multi-point inspection that was done after I had taken the vehicle in for other maintenance work.
Old Aug 4, 2021 | 02:04 PM
Daneel227's Avatar
Picked up vehicle today (08/04/2021) from the dealership "Jaguar Land Rover of Troy" (Troy, MI). During multi-point inspection (as stated from the outset) "coolant low light activated. The system was pressure tested and found coolant leaking from lower coolant outlet pipe. Replaced upper and lower coolant outlet pipes and rear crossover." Parts used: 1 - pipe-outlet; 1 - Tube; 1 - Pipe Heater; 2 - Gasket; 1 - Gasket -Indctn M; 1 - BG Coolant. Total parts: $424.45; Labor: $1372.70
Water pump was not replaced, the issue was not even addressed. Should it have been and why?
Old Aug 5, 2021 | 11:06 AM
clubairth1's Avatar
If you can see the updated blanked off plastic "Y" fitting then you have the latest and greatest water pump with the part number that ends in 3909.
I guess if yours was not leaking they would not have replaced it. But yes it needs replaced unless you have the current revision.
This thread may help you identify if you have the updated pump. There were a few other changes too that if there does show you have the upgraded-newest pump.
Water Pump Identification
Ken2839
Oct 3, 2016 09:42 PM
Drak
Dec 11, 2015 03:45 PM
Muslima36
May 1, 2014 07:22 PM
stephen11962
Dec 6, 2010 07:38 AM
sinatrakat
Sep 13, 2010 04:20 AM
