XJ ( X351 ) 2009 - 2019
Dead battery. Cannot access trunk.
Old Apr 29, 2026 | 04:25 PM
Lanezz's Avatar
Default Dead battery. Cannot access trunk.
Hello everyone. My 2016 Jaguar XJL has been sitting for several months now. I had to replace all of those cheap plastic parts that were causing coolant leaks. Now that they have been replaced, the big problem is getting into the trunk open to change the battery. We've tried supplying power via under the hood. It didn't work. Now we are trying to supply power via the area behind the rear seat. We were able to remove the bottom portion of the seat but are unable to figure out how to remove the back part of the seat. Any help would be greatly appreciated. The dealer wants me to have it towed in, but I am reluctant because there have been horror stories about mechanics tampering with vehicles causing issues in order to get customers to pay large sums of money to have said issues fixed. It's puzzling to me that the manufacturer did not think it necessary to have a keyhole installed in this model so that the customer can manually open the trunk.
Sincerely,
Tired of walking
Old Apr 29, 2026 | 08:24 PM
wombat's Avatar
Check out the "Sticky" at the very top of the opening page, "Getting into the trunk with the battery disconnected". The basics are; there is a connector behind the rear seat back, that when supplied with 12v, will open the trunk lid.
wombat
Old Apr 30, 2026 | 12:27 PM
clubairth1's Avatar
Community Influencer
Is the battery still connected or has one or both terminals been removed?
I had trouble getting the top section of the back seat to fold forward as shown in the workshop manual.
I have circled in red the bar the straps pull on to release the seat back. I had to pull very hard to get the latch to release.
In the thread listed by Wombat above you can see this tail sticking out from under the seat back.
But no matter how hard I pulled the strap I could not get it to release. So keep at it as I finally got enough force on the strap to release the seat back.
Now it folds forward but is still attached to the car so difficult to work around.
Old Apr 30, 2026 | 06:57 PM
Lanezz's Avatar
The battery is still connected. I'm going to check again for the strap, but I don't remember seeing. I'll get back to you.
Old Apr 30, 2026 | 08:58 PM
RoverJoe's Avatar
powering it from the jump points underhood won't give you enough to release the trunk with the button?
Old May 1, 2026 | 03:02 PM
XJsss's Avatar
From my old manual
File Type: pdf
Jagicon
Jul 6, 2022 03:51 PM
Rankster
Jun 10, 2020 02:23 AM
redxk8
Jun 21, 2019 01:39 PM
gagman66
Jan 19, 2017 07:46 PM
JagX02
May 12, 2014 01:22 PM
