XJ ( X351 ) 2009 - 2019
Does anyone know why it’s making this sound ?
Old Jul 5, 2025 | 02:58 PM
Jman84's Avatar
Default Does anyone know why it’s making this sound ?
It just stared making this sound the other day an it’s getting worse does any one know what it could be before I take it to a mechanic
Old Jul 5, 2025 | 04:08 PM
Thermo's Avatar
Veteran: Navy
Jman84, could you please tell us what year your car is and what motor is in it. That may help us out here. The next question that I have is if you recent hit a pothole or something that resulted in the car bottoming out. I am assuming you are probably also noticing a bit of power loss too. I am thinking you have something that has damaged the exhaust pipe and this is causing the exhaust to become backed up and go through a restricted area. That sound reminds me of what an I4 engine sounds like when they use a really restrictive exhaust system. I think a good look underneath may tell you all that you need to know.
Old Jul 5, 2025 | 05:05 PM
Jman84's Avatar
Thermo
its a 2015 3.0 aj126 supercharged engine I did bottom out leaving my brother in law drive way last night but it started about 2 days ago
Old Jul 6, 2025 | 08:45 AM
clubairth1's Avatar
Community Influencer
If you can't or won't DIY what choice do you have but to take it to a shop?
Old Jul 6, 2025 | 09:51 AM
Thermo's Avatar
Veteran: Navy
Jman84, you don't mention any lights on the dash that occurred as part of this (ie, check engine light, ABS light, etc). If you do have the check engine light, then please go to a local auto parts store and have them read the codes and then post them here. that will help us figure things out.
Barring all this being good, I think the next step is to have an exhaust shop take a look at the car and see what they say. Unless you somehow had a large pressure pulse go through the engine that damaged both cats or both mufflers, I would expect to hear a difference from side to side of the car. Once they start looking underneath the car, I think the problem is going to be pretty obvious.
Sampson
Apr 30, 2023 12:02 AM
jomo
Apr 5, 2022 01:04 PM
Jason.
Feb 18, 2022 08:26 AM
Dell Gailey
Aug 23, 2018 03:07 PM
nthegrip
Sep 13, 2009 10:30 PM
