XJ ( X351 ) 2009 - 2019
Drop engine to remove exhaust manifold on 3.0D
Old Apr 14, 2024 | 01:37 PM
ronzinio's Avatar
Default Drop engine to remove exhaust manifold on 3.0D
Before I even start confirming that I need have a cracked exhaust manifold, I just wanted to know if to replace it, the engine needs removing.
i just removed the EGR cooler which was a tight squeeze. Had smoke coming from LH side of engine. Inlet manifold has to be be changed due to restricted performance and then I discovered a coolant leak which has been resolved but smoke seems to also be coming from below that
Old Apr 14, 2024 | 04:55 PM
Vasara's Avatar
No need to remove engine from vehiclr for exhaust manifold. If you already removed the EGR the worst is behind (respect), exep turbo to manifold bolts can be tricky.
Brewtech
Jun 3, 2022 09:23 PM
Jay111
Apr 23, 2022 12:40 AM
ramskifast
May 12, 2017 09:05 PM
Muddybear
Aug 29, 2016 03:43 PM
Ericbilt25
Mar 26, 2014 08:01 AM
