XJ ( X351 ) 2009 - 2019
Front sunroof blind repair on 2011 XJL
Old Oct 10, 2016 | 08:54 AM
Damon_Silvestry's Avatar
Unhappy Front sunroof blind repair on 2011 XJL
I noticed that my 2011 XJL front sunroof felt was sagging a bit. I tried to open the front sunroof blind and I heard a snap. The blind now no longer opens or closes.
I hear the mechanism turning. However, the blind looks like it separated from the turning mechanism.
Any suggestions on how to repair?
Old Oct 10, 2016 | 09:21 AM
RoonieQ's Avatar
This exact issue and symptoms happened to me recently; luckily repaired while still under warranty so I am unable to attest to cost.
Service note indicates the following:
"Drop headliner and check both motors. Found front blind motor binding causing front blind failure. Install new front blind motor and clips, recheck after roof headliner install. Both blinds working normal."
Three parts are listed on the work order:
1- C2D23452 - KIT-CASTING SERV
2- C2D30281 - BLOCK-SLIDING
2- C2D30280 - BLOCK-SLIDING
REPAIR CODE:
761439 ROOF PANEL FRONT BLIND MOTOR AND CASING - RENEW 549 WJ 1.70
Car was in the shop overnight. Good luck.
Old Oct 16, 2016 | 04:37 PM
Acer721's Avatar
I'm having the exact same issue. The roller turns in both directions, but the blind doesn't move. It's like something is just disconnected.
Old Oct 18, 2016 | 03:18 PM
LaCapitalRue's Avatar
Angry
I had the same issue. My repair was same as RoonieQ...cost me $293 out of pocket...my aftermarket "Platinum" warranty classified the parts as "Trim" which are excluded
xk8newbie
Feb 3, 2017 10:20 PM
MK2
Oct 11, 2016 07:55 AM
AbyJag
Oct 9, 2016 03:15 AM
john_cook12
Oct 8, 2016 12:18 AM
SovietKitsch
Oct 6, 2016 12:56 PM
