Front Suspension
Welcome to the forum emadkomar1,
I've moved your question from General Tech Help to X351 forum. This is the place to post technical questions about your model.
Received 3,825 Likes
emadkomar1, this has been a topic of discussion on here lately. This is what I want you to try: using a jack, raise the front end of the car off of the ground and support the car via the frame (not by the suspension) such that both front wheels are off of the ground for a period of say 2 hours. As quickly as you can, lower the car back down to the ground and take it for a spin over a bumpy surface. Does the noise appear to be gone/severely diminished? If yes, then your problem is the bushings for the sway bar. These bushings are known to get deformed over time we are finding out and this will allow a gap to form around the sway bar and allow it to move a little as the suspension works, resulting in the knocking that you are hearing.
Sway bar bushings are always the first suspect when it comes to front suspension clunks.
carter333167
11-27-2012 10:24 PM
Jayshmie07
07-08-2012 04:24 PM
MANIACK
05-30-2012 09:06 AM
catniped
04-19-2012 11:13 AM
jaguarNeWb
12-01-2010 09:42 PM
