XJ ( X351 ) 2009 - 2019
Front Suspension
Old Jul 21, 2018 | 09:58 AM
emadkomar1's Avatar
Default Front Suspension
I have a 2011 Jaguar XJL Supercharged and having front rattling sound coming from both side and have changed both struts, u joint and control arms and still having the rattling sound. Please help
Old Jul 21, 2018 | 05:12 PM
Welcome to the forum emadkomar1,
I've moved your question from General Tech Help to X351 forum. This is the place to post technical questions about your model.
Old Jul 21, 2018 | 06:05 PM
Thermo's Avatar
Veteran: Navy
emadkomar1, this has been a topic of discussion on here lately. This is what I want you to try: using a jack, raise the front end of the car off of the ground and support the car via the frame (not by the suspension) such that both front wheels are off of the ground for a period of say 2 hours. As quickly as you can, lower the car back down to the ground and take it for a spin over a bumpy surface. Does the noise appear to be gone/severely diminished? If yes, then your problem is the bushings for the sway bar. These bushings are known to get deformed over time we are finding out and this will allow a gap to form around the sway bar and allow it to move a little as the suspension works, resulting in the knocking that you are hearing.
Old Jul 23, 2018 | 12:04 PM
XJ8JR's Avatar
+1
Sway bar bushings are always the first suspect when it comes to front suspension clunks.
Old Jul 23, 2018 | 11:42 PM
emadkomar1's Avatar
Thank you everyone, I'm taking every opinion seriously and will let know of the results. Thank you again
Old Jul 24, 2018 | 09:09 AM
XJsss's Avatar
Here is what was replaced on my SuperSport when I had clunking and rattle in my front suspension and it cured the issue. This repair was over six months ago and still no issue.
Old Jul 24, 2018 | 10:01 PM
emadkomar1's Avatar
Thank you for sharing this information, but I'm still looking for trusted technicians who could do to work in my area.
carter333167
Nov 27, 2012 10:24 PM
Jayshmie07
Jul 8, 2012 04:24 PM
MANIACK
May 30, 2012 09:06 AM
catniped
Apr 19, 2012 11:13 AM
jaguarNeWb
Dec 1, 2010 09:42 PM
