XJ ( X351 ) 2009 - 2019
GPS Antenna
Old Jul 25, 2020 | 04:59 PM
leroycarls's Avatar
Default GPS Antenna
Where is the GPS Antenna located on a 2015 XJL...I think that is my navigational problem....
Old Jul 26, 2020 | 07:00 AM
XJsss's Avatar
It's in the shark fin above the rear window.
Old Jul 26, 2020 | 03:10 PM
leroycarls's Avatar
Can I get at the fin from inside the ceiling light???Does that come apart???? There may be a disconnect or???? or needs a new fin or ????
Old Jul 27, 2020 | 03:04 PM
clubairth1's Avatar
Community Influencer
The headliner has to come down and it's bolted to the roof.
Looks like this when you get to the bolts;
But it's not a problem that's been reported and you should get it diagnosed before just replacing parts?
Have you run the codes using a SSD type scan tool?
Might be something simple and cheaper?
Old Jul 28, 2020 | 08:10 AM
leroycarls's Avatar
Thank you....will do as you suggest........L carlson
Old Jul 28, 2020 | 12:22 PM
clubairth1's Avatar
Please post back if you get it fixed. It sure can help the next guy out!
aeginc77
Nov 23, 2023 05:30 PM
Daytona
E type ( XK-E )
25
Oct 29, 2020 10:45 AM
flycasterwa
Nov 12, 2012 03:21 PM
scottatl
Sep 10, 2010 11:54 AM
