XJ ( X351 ) 2009 - 2019
Headlights will not turn off
Old Jun 1, 2015 | 08:14 PM
fredn's Avatar
Default Headlights will not turn off
My 2008 XJR has an "Auto" setting for the headlights. When I use it, the lights do not turn off when I turn off the ignition. The "headlight on" beeper sounds and I have to turn the switch to "off". This has just started. I have owned the car three years with no such problem previously.
Old Jun 2, 2015 | 08:04 AM
Delta-V's Avatar
Have you tried jiggling the stalk to see if they turn off? I have a similar problem. Never does it at the dealer, of course.
Old Jun 2, 2015 | 11:38 AM
fredn's Avatar
Thanks. I had not tried that (but will). I had understood that it may be some type of problem in the turn signal stalk (dealer wants $$$$ to check it out). Ever heard of that?
Also, I am new to this forum. Did I post this correctly and in the correct place?
Old Jun 3, 2015 | 07:55 AM
Angus's Avatar
You'll probably have more luck in the X350/X358 forum.
Certainly in the X100 XKs there have been problems with soldered joints going bad in the indicator stalk, might be worth a search.
I hope you find a solution without causing your wallet too much grief!
This might point you in the right direction (it's slightly different, but in the area I was thinking of):
https://www.jaguarforums.com/forum/x...riving-125570/
Old Jun 26, 2015 | 05:03 AM
uh2's Avatar
uh2
I have this same issue with my X351. Sometimes if I leave it in auto, and turn the ignition off, the car acts like I need to turn the lights off. Sometimes it flashes the warning on and off. Another issue I have is that sometimes, mostly when it's a little cloudy outside, and sometimes when it's clearly sunny, the auto lights turns on and off by themselves. It looks like I'm flashing the car in front of me.
I've taken video of all of this and will be dropping it off next month.
99xk8guy
May 28, 2024 09:36 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
