XJ ( X351 ) 2009 - 2019
Heater control module
Old Oct 18, 2017 | 09:51 AM
alanhodges's Avatar
Default Heater control module
Hi
Has anyone got any idea where my Heater control module and also what it may look like. So at least I'll know what I'm looking for. My car is a Jaguar XJ 2012
Thanks in advance
Regards
Alan
Old Oct 19, 2017 | 10:28 AM
hafren's Avatar
Look at the attached and search "cntrl F" for C2H101A which is a connector attached to the climate control module.
File Type: pdf
Old Oct 19, 2017 | 02:32 PM
alanhodges's Avatar
You are an absolute star mate. Thank you very much. I notice the diagram is of a L/H drive car, will it be on the same side or different on a R/H drive.
Alan
Old Oct 19, 2017 | 03:42 PM
xdave's Avatar
It will be reversed; i.e. above the passenger footwell LH side.
Old Oct 19, 2017 | 03:45 PM
alanhodges's Avatar
Cheers Xdave
Old Oct 19, 2017 | 04:08 PM
alanhodges's Avatar
Where would I be able to get this information/diagram, can you buy it or doe's it come from jaguar services only.
Alan
Old Oct 20, 2017 | 05:19 AM
xdave's Avatar
The diagram is from the electrical wiring diagrams (EWDs) on https://topix.jaguar.jlrext.com/topix/user/loginForm. Anyone can register there, but there is a fee to access the information which differs based on the models and length of access you require.
What is it you need to do with your module? Are you replacing it? I can grab the workshop instructions for removing the module later if needed.
Old Oct 20, 2017 | 01:03 PM
alanhodges's Avatar
WOW that would be great if you could.
I'm having a problem with the passenger side front and the same side behind. There's no heat and the blower doesn't seem to blow air out either. Driver and seat behind, all work fine. I've look around for help on the net, no joy. I'm at a loss, the local dealership want's 1600,for doing the fix. I can't afford to pay that, so it's up to seek and destroy lol
Any help diagrams or components of the heater/cooling system would help me out.
Thanks for your help so far.
Alan
Old Mar 5, 2020 | 08:31 AM
philatkins's Avatar
Default cold air on passenger side
Hi Alan, I see that this is an old post but I was wondering if you have fixed this problem as I have the same on my 2011 X351?
If I do HARD reset by disconnecting the Battery positive for 30 mins then the Climate Control works perfectly for a few days but then reverts to Cold Air on Nearside of car.
Would love to know how you got on.
Thanks in advance.
Phil
Old Mar 6, 2020 | 02:06 AM
christ's Avatar
Wow. Old thread.
Old Mar 6, 2020 | 03:33 AM
philatkins's Avatar
Yes, I said it was. Has anyone replaced an ATC module on an X351?
Old Mar 16, 2024 | 06:03 AM
danu99's Avatar
I believe I have the same problem.
B11ed-87 electric heater control module- permanent error. Is the code above the part number for the piece?
And…. Has anything to do with fan blowing hot and cold air at the same time on the passenger side for a left drive car? Driver-left side is cold ok.
The passenger side I think it uses the electrical heater to make cold air from the cooling system hot again.
Help?
Old Mar 16, 2024 | 06:31 AM
Vasara's Avatar
The electric heater is last device on LIN-bus controlling the left side air circulation flaps. Failure can mess up the comminication and left side flaps enter on uncontrolled state
Happens on my friends XJ and after we changed the control printed circuit board of the heater on site, the control of the flaps returns. (bit tricky to change it, but still less work than change whole heater. (LHD driven vehicle)
Old Mar 16, 2024 | 06:44 AM
danu99's Avatar
Some part number to look for? Thanks for the info
Old Mar 16, 2024 | 09:11 AM
Vasara's Avatar
My friend bought used electric heater module from brokeyard and we took the controller from that. By quck search try MF013410-0451
Old Mar 16, 2024 | 09:25 AM
clubairth1's Avatar
Community Influencer
We need to be careful here?
ONLY the Diesel versions of the X351 came with this auxiliary electrical heater. No gas engines did and in the US we never got the Diesel versions.
Old Mar 16, 2024 | 09:52 AM
Vasara's Avatar
This is correct!!
Old Mar 16, 2024 | 10:29 AM
danu99's Avatar
This is correct!!
Thanks guys. I have diesel 3.0. I even found the part after code. 40 euro. With warranty. Brand new second hand😂😂
After it the weather warms up… will give it a try….myself.
Old Mar 18, 2024 | 03:10 AM
danu99's Avatar
This is correct!!
Guys…. X351 is drive by wire or mechanical? Could be a problem with steering wheels sensor?
Old Mar 19, 2024 | 07:55 AM
clubairth1's Avatar
The throttle is DBW (No Cable)? Is that what you meant? But that's not related to anything in the steering?
Now some Jaguars also got electric steering depending on the year so that would be DBW too I guess?
