XJ ( X351 ) 2009 - 2019
How do I control rear AC only?
Old Jan 31, 2011 | 02:19 AM
jaguarman's Avatar
Default How do I control rear AC only?
When I set the unit to rear and turn on the rear a/c to full blast its tied to the front - meaning I cant get the front off and the rear on independently - I click on rear (the rear is lit) turn up the AC and then the front blower gets loud and the front and rear start blowing - very frustrating - any help?
Old Jan 31, 2011 | 12:26 PM
gears's Avatar
I wondered the same. I seriously suspect there is no separate fan for the rear. All my other cars in that class had a separate fan for the rear.
Feels like they skimped on this one.
Old Jan 31, 2011 | 03:25 PM
ExpatJag's Avatar
And it is not just that the fan is on but there is still air blowing out of the defrost vents near the windshield. I would consider this a biggie guys. How do you call it 4 way climate control is you all use the same fan speed?
Old Feb 4, 2011 | 10:07 AM
gears's Avatar
Good point. I will play with mine a bit. I'll let you know. I don't think my front blows in the case you described. I will double check and let you know. May be something isn't working correctly in yours. I will turn up the back and let you know if the front still blows.
Calling it a real 4 zone would be simply misleading and false if that is the case. Back to my 2002 X5 and my 2008 CLS63 the 4 zone is a real 4 zone with seaparate fans for front and back.
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Sep 25, 2015 11:09 AM
