XJ ( X351 ) 2009 - 2019
I blew my engine?
Old Feb 22, 2024 | 08:18 PM
xalty's Avatar
what was oil level like...these don't give you any warning
Old Feb 22, 2024 | 09:39 PM
OzXFR's Avatar
Agreed.
If it is as I suspect one or more spun rod bearings then something must have caused that to happen, and the prime culprits are low oil (or maybe but rarely plenty of oil but low oil pressure) and overheating (almost always due to loss of coolant).
If the OP does spring for a replacement engine then it would be nice to see a teardown of the blown engine which may in turn reveal the cause(s).
Maybe sell the blown engine to I Do Cars and recoup something?
Old Feb 23, 2024 | 06:44 AM
clubairth1's Avatar
Community Influencer
Yes I have posted this multiple times before.
I use Mobil 1 ESP X2 0W-20
Here is the spec on the back of the bottle.
Old Feb 23, 2024 | 04:24 PM
12jagmark's Avatar
My apologies, that completely slipped my mind.
Although there are several Mobil-1 0W-20 and 5W-20 oils available, I have never been able to locate that spec of Mobil-1 ESP X2 anywhere near where I'm at.
Where do you get that from?
Was the OP using the ESP X2 0w-20?
Old Feb 23, 2024 | 04:38 PM
lotusespritse's Avatar
Pretty much if it isn't on Amazon, it doesn't exist, lol.
Amazon Amazon
Old Feb 24, 2024 | 09:46 AM
clubairth1's Avatar
Yes that is one I use. Pretty easy to find but your right in that Mobil and all the rest have multiple products with very similar names. The Castrol Edge stuff must come in at least 5 or 6 varieties and it's ALL called Edge.
I can get it as posted above on Amazon or EBay just depends on which has the best price.
Old Feb 28, 2024 | 08:53 PM
tjankovs's Avatar
Originally Posted by OzXFR
Agreed.
Oil is full (see beginning on video) and temp was normal. I was cruising gently at 80mph when it happened.
Here is my replacement...hopefully it will hold up to my driving a bit more. I miss the extra leather and wood, not the sticky buttons or tech though. Still need to figure out what to do with the XJ. Mint condition otherwise.
TJ
Old Feb 29, 2024 | 08:58 AM
  #28
clubairth1's Avatar
That 392 is a fast machine!
Old May 16, 2024 | 10:44 PM
tjankovs's Avatar
Well...I received the Blackstone report back. Looks like the oil dilution/degradation was not the cause. It's odd...appears the the bearing wore over time as there was normal aluminum on the sample...allegedly the top layer. So longer term wear vs. a catastrophic event? What do you guys make of the report? The engine fires right up, runs smooth, no smoke, just sounds awful.
TJ
File Type: pdf
Old May 17, 2024 | 06:05 AM
  #30
Baltobernie's Avatar
Here is my recent XJ V-8 oil analysis for comparison. The Blackstone comments appear to be spot-on.
File Type: pdf
Old May 19, 2024 | 03:08 PM
  #31
Jaaag_drivah's Avatar
Intermittent knock sensor code is the red flag here. Pair a lean condition with your (stated) aggressive driving style and you get a spun rod bearing.
The video doesn’t sound too bad. If you get the engine rebuilt now and don’t drive it any longer, you may be able to save the block and crank. At this point, an engine rebuild is worth pretty close to the value of the car. Without it it’s worthless unfortunately, you may get $2K selling the car for spares.
Old May 20, 2024 | 03:48 PM
  #32
dmchao's Avatar
Thanks for posting your oil analysis. That info always helps other owners.
Piersman
Apr 16, 2023 11:45 AM
BRGX
Jan 5, 2019 04:15 AM
markocosic
Jun 26, 2016 03:08 PM
santer
Sep 25, 2015 03:28 PM
Bug Splat
Apr 29, 2013 07:16 PM
