XJ ( X351 ) 2009 - 2019
Illuminated door sills
Old Nov 17, 2016 | 08:09 PM
msp843's Avatar
Default Illuminated door sills
I just recently purchased a 2016 Jaguar xj l (love it) and am looking for some illuminated door sills. I've looked on ebay but haven't seen any that look like they will fit a 2016. Has anybody found any that will fit? Can you forward the link? Thanks in advanced
Old Nov 18, 2016 | 01:08 PM
Thermo's Avatar
Veteran: Navy
msp843, go to Jaguar Parts, put in your car information and from there, you can find the door sills under the body parts section. If I remember right, the plugs are already under the door sills that you currently have. So, getting them to work should be no issue. As for price, well, be ready for a shock.
Old Nov 18, 2016 | 06:37 PM
Stuart S's Avatar
See my thread from last year: https://www.jaguarforums.com/forum/x...plates-153556/
They're "officially" called scuff plates in the Jaguar parts catalogs.
2016 XJL from: https://jaguarmerriamparts.com/parts...?siteid=215718
Part Number: C2D30454 Scuff plate, front, illuminated right: $189.12
Part Number: C2D30455 Scuff plate, front, illuminated left: $189.12
They don't show illuminated scuff plates for the rear.
I believe that the 2016 scuff plates are aluminum, which accounts for the significantly lower prices than in earlier models that were stainless steel.
For my 2013 XJ (short wheelbase), from: https://jaguarmerriamparts.com/parts...?siteid=215718
Part Number C2D22752 Scuff plate, front, illuminated right: $291.95
Part Number C2D22753 Scuff plate, front, illuminated left: $291.95
Part Number C2D22754 Scuff plate, rear, illuminated right: $284.11
Part Number C2D22756 Scuff plate, rear, illuminated left : $291.08
For the 2013 XJL, from: https://jaguarmerriamparts.com/parts...=scuff%20plate
Front, R&L are the same as the SWB, above. Rear are different.
Part Number C2D22755 Scuff plate, rear, illuminated right: $291.08
Part Number C2D22757 Scuff plate, rear, illuminated left : $291.08
Fronts are the same size for swb or lwb, but rears are different - longer for the lwb models.
I believe, but am not absolutely certain, that the stainless steel illuminated scuff plates from the pre-2016 model years will fit the 2016 model. To be certain, ask your Jaguar dealer.
Stuart
Old Nov 18, 2016 | 06:59 PM
msp843's Avatar
Great info, thanks for your help!
Old Jan 10, 2017 | 02:22 AM
Z20's Avatar
Z20
Will the 2016 illuminated door sills fit earlier XJ's or XJL's? That is a significant savings per door. And since I am planning on buying some very soon I would love to save a few dollars.
Old Jan 10, 2017 | 11:23 AM
Stuart S's Avatar
I think they will, but check with your dealer to be sure. See my Post #3, above.
