XJ ( X351 ) 2009 - 2019
Installing Sound Deadening Mat (KilMat) behind rear seats
Old Jun 7, 2020 | 08:57 PM
Supercharged Jag's Avatar
Default Installing Sound Deadening Mat (KilMat) behind rear seats
Hello everyone, I’ve installed kilmat in the trunk yesterday, and it reduced my exhaust noise/drone pretty noticeably. But it’s still pretty bad. I want to install kilmat behind my rear seats to help a little more. My question is there is a foam mat or something behind the seat, is that easily removable? If so should I install behind that mat and then reinstall the mat or should I just remove the mat after installing? Or should I just install over the mat?
Old Jun 8, 2020 | 12:19 PM
clubairth1's Avatar
Community Influencer
On my 2014 there is a big thick rubber mat behind the rear seats. Not sure you would gain much by adding to that?
You can inspect this mat by putting the rear seat arm rest in the down position. Then the fabric cover underneath can be peeled back as it's Velcro. There is also another fuse box the mat covers.
Take a look and see what you think?
Old Jun 8, 2020 | 03:21 PM
bullittandy's Avatar
I added mass loaded vinyl above the mufflers in my car. I added some on the outside of the car on top of the heat shields and then also more on the inside of the trunk on top of the mufflers and that worked well. I also added a large piece across the top of the spare tire well but recently removed that and didnt notice an increase in drone.
sfdoddsy
Sep 17, 2017 07:54 AM
Jag4
Aug 10, 2017 08:43 PM
scarbro2011
Dec 8, 2015 06:17 AM
rama1200
Apr 5, 2011 06:38 PM
pnyklr
Nov 12, 2010 05:39 PM
