XJ ( X351 ) 2009 - 2019
Looking for exact location of hood switch on XJL
Old Nov 5, 2018 | 05:18 PM
Jay Govan's Avatar
Default Looking for exact location of hood switch on XJL
Having continuous open hood warning light on dash. Can someone help me locate the switch?
Thanks in advance
Old Nov 6, 2018 | 02:30 AM
xdave's Avatar
The switch is in the left hand latch mechanism, and can be accessed by removing the shroud. (C1PL25)
They are a common failure point. If removing the latch to clean/check/replace it is too much effort, or you need a quick way to lock the car, you can just dead short that connector out with a piece of wire pushed into the connector.
Old Nov 8, 2018 | 10:44 AM
Nexsen's Avatar
Thanks. But is C1PL25 the switch to short or the shroud removed? A lot of connectors are shaded in purple.
Old Nov 8, 2018 | 01:01 PM
xdave's Avatar
Apologies, my message was a bit confusing there.
C1PL25 is the connector. It is plugged into the right hand side of the bonnet/hood latch mechanism where the tip of the arrow is.
You need to remove the plastic cover from the front of the engine bay (they are fitted with torx screws on the X351) then you can access the connector to remove it.
Then short between the two female pins on the connector to make the car believe the switch is closed.
Once you have exposed the latch it is worth checking to see if it is just stuck, and that the connector itself was securely fitted.
Old Nov 10, 2018 | 10:26 AM
Nexsen's Avatar
Thank you. I should be able to solve this problem with the excellent information you have provided. I appreciate it very much.
djdex
Mar 26, 2025 05:31 AM
Foosh
Jan 11, 2021 01:32 PM
Ubad2
Feb 18, 2018 11:01 AM
thomash85715
XJ40 ( XJ81 )
Apr 20, 2011 11:25 PM
hlgeorge
May 5, 2010 08:29 PM
