XJ ( X351 ) 2009 - 2019
My 2017 Jaguar XJ won’t start (TRANSMISSON NOT IN PARK) help
Old Feb 14, 2024 | 06:54 PM
Corey5041829's Avatar
Default My 2017 Jaguar XJ won’t start (TRANSMISSON NOT IN PARK) help
Hey you guys my 2017 Jaguar XJ has been running fine 28,000 miles. Last week I pulled up to store went into the store came out went to start the car it would not start massage on dash said transmission not in park , transmission fault, parking brake is in maintenance mode, aspc not available, 2 wheel drive only traction reduced, put the ob reader on it and it pulled U0101 code lost Communication with TGM . Can someone give some insight I would appreciate it.
Old Feb 15, 2024 | 09:45 AM
Vasara's Avatar
Your might have just an weak battery.
Old Feb 15, 2024 | 02:34 PM
Baltobernie's Avatar
Maybe you could try releasing the transmission using the emergency strap. See instructions in the owner's manual. Perhaps this will allow the starting sequence to continue with the transmission in Neutral (at least functionally, if not electrically).
Old Feb 17, 2024 | 08:55 AM
clubairth1's Avatar
Community Influencer
Focus on the battery as Vasara posted above ...first.
How old is it?
What are the voltage readings? Engine off and running?
khalid mahmoo
May 8, 2023 11:53 PM
keitheva
May 24, 2018 06:30 PM
karhudso
Apr 3, 2018 04:48 PM
yidal8
Sep 22, 2016 07:52 PM
apachegogo
Jan 9, 2016 10:04 AM
