XJ ( X351 ) 2009 - 2019
Navigation Sensitivity
Old Jan 22, 2016 | 12:17 PM
Aaron Jacob Doughty's Avatar
Default Navigation Sensitivity
Is there a way to adjust the sensitivity on the display screen? Seems I've got to push fairly hard to submit a command.
Old Jan 22, 2016 | 01:37 PM
xdave's Avatar
I see from another post that you have a 2011 XJ. The touch screen systems in the 2010-2013 model year XJs are sadly like that. How it got past QA I don't know.
Over years of use now with mine I've found that touching slightly above where you want to touch and holding for a second tends to hit it 95% of the time. The duration seems to be the main requirement, not the amount of pressure applied.
Old Jan 22, 2016 | 01:40 PM
jimbov8's Avatar
If memory serves, I think there is an alignment procedure for the screen. You will have to consult your manual for the instructions.
Jimmy 68
Jan 26, 2026 06:02 PM
Rodney Gold
Jan 22, 2016 06:31 AM
meirion1
Jan 21, 2016 03:34 PM
Ubad2
Jan 19, 2016 08:10 AM
pinninni56
Jan 18, 2016 03:17 PM
