XJ ( X351 ) 2009 - 2019
Need Help - coolant leak
Old Jun 2, 2022 | 08:08 AM
ROB281's Avatar
Default Need Help - coolant leak
Morning everyone,
I literally just created this account and have begun the search for trying to pinpoint the source of my leak, but in the meantime I wanted to create describing my issue to see if anyone has experienced anything similar.
I was driving my wife’s XJL last week and noticed the smell of a coolant leak, but it was faint.
Yesterday I was doing some spirited driving in and noticed steam coming from under the hood. I opened the hood and noticed that the steam was coming from the oil filter housing area. But no visible trail or pooling was present.
I got home yesterday evening and had the low coolant light on, topped the system off and noticed a steady drip coming off the aero pans where the transmission sits.
Could I have multiple hoses that decided to let go at the same time? Or would a leak at the thermostat area travel that far back?
thanks in advance for any tips!
Old Jun 2, 2022 | 09:53 AM
atraudes's Avatar
Try checking again after it's sat overnight and everything is cool and dry. When coolant dries it'll usually leave a white outline which makes it much easier to see than when it's wet. You're going to need to pull the belly pan off and really give it a thorough check. An inspection mirror will help a lot. If it's just sort of all over the place, you can wipe it off with a damp cloth and then check again after another drive.
Good luck!
Old Jun 2, 2022 | 12:56 PM
ROB281's Avatar
I had to take a drive today, and I have coolant all over the pulleys., and collected in the belly pan under them. I feel it's safe to assume the water pump is shot.
Old Jun 2, 2022 | 12:59 PM
atraudes's Avatar
If you don't know when it was last done, it's due anyway Actually, the same applies to all of the plastic coolant hoses too, which could also be the culprit.
This thread is a good reference for both, if needed:
https://www.jaguarforums.com/forum/x...eplace-256437/
Old Jun 2, 2022 | 02:12 PM
clubairth1's Avatar
Community Influencer
Please post the engine and mileage and year?
There are a number of things that need to be done and the water pump is just the beginning.
I would stop driving the car now until it's been repaired.
Now the big question is will you DIY the repairs or pay to have the work done? If paying expect a large multi-thousand dollar bill.
It's all documented here on the forum if you do go the DIY route.
That's a good thread posted above to start with but we have many more too. Don't forget the rear water manifold as it's much easier to get to with the SC removed.
Old Jun 2, 2022 | 02:23 PM
ROB281's Avatar
2016 3.0 57k & some change
Working through a bunch of threads now tracking down all the parts... I'm a glutton for punishment
Haven't found the part # for the rear water manifold yet
Old Jun 2, 2022 | 05:16 PM
12jagmark's Avatar
Rock Auto has at least one of the plastic pipes available-
2016 JAGUAR XJ 3.0L V6 Supercharged Coolant Hose Connector / Flange | RockAuto
Old Jun 4, 2022 | 10:09 AM
clubairth1's Avatar
If your serious we now have several of the failure prone parts come out in lifetime Aluminum!
This is a great thing and I hope they continue and add more Al. parts!
So the 2 big ones in front of the engine. Note these are only for the SC cars as the NA ones use a different pipe.
Al. Cooling Pipes
Also the tube from the water pump to the oil cooler. This is a bit hard to get stabbed when putting the engine back together and has caused leaks. This appears to fit ALL engines too. 2.0,3.0 and 5.0L versions.
Al. Water Tube
Old Jun 4, 2022 | 10:57 PM
ROB281's Avatar
Al. Cooling Pipes
Al. Water Tube
definitely serious, I’ve got some parts ordered and on there way already, will take a look at your aluminum parts.
Old Jun 5, 2022 | 06:38 AM
leaddog11's Avatar
Originally Posted by ROB281
Morning everyone,
apparently a common problem with these cars. Really have to keep an eye on them. What engine do you have and your mileage on car?
Old Jun 14, 2022 | 02:51 PM
ROB281's Avatar
Trying to finish the water pump replacement today.
Noticed that there is grey connector under the TB that appears to be missing a hose to the lower right.
I saw no unattached hoses anywhere, where should that connect?
Old Jun 14, 2022 | 04:14 PM
XJsss's Avatar
Don't worry about it as it is not used and it is not open on the end.
Old Jun 15, 2022 | 06:10 AM
ROB281's Avatar
Thanks!
Old Jun 23, 2022 | 07:55 AM
Sabrinaservicewriter's Avatar
Hi! I am a service writer at my family's Jaguar repair shop and have had tons of experience with the coolant leaks on the 3 and 5L Jaguars. I posted this in the thread someone referred to up above but here is a list that may help you!
I have done a lot of research and have a great relationship with my local Jaguar dealership parts department and can provide you with the land rover part numbers for some of the other parts needed for this job. Hope this helps!
  1. AJ813565 -LR092992
  2. C2Z28467 -LR049989
  3. AJ89664 -LR018275
  4. AJ813909 -LR097165
  5. C2Zl8658 -LR028136
  6. AJ811539 - LR030593
  7. AJ814007- LR109402 this part number can also be found as C2Z31645 it was the original part numbe
I hope this helps! If you need help tracking down any other parts, don't hesitate to reach out, I'm glad to help!
Old Jun 24, 2022 | 06:35 AM
leaddog11's Avatar
Thank you very much. Most helpful!!
Old Jun 25, 2022 | 12:17 PM
Ken O's Avatar
Is this the same list for a 2013 3.0?
Old Jun 27, 2022 | 10:05 AM
Good Morning Ken O!
For the 2013 XJ 3.0L SC there are other parts that would be needed.
I pulled a repair order from one we did last week, same year and model. Here are the parts we replaced for that engine:C2Z18677
C2Z28258
AJ814053
C2Z17429 (2)
C2Z17248
AJ813865
C2Z26930
AJ813917
C2D6362
C2Z18658
AJ811539
AJ813909-Water pump
Hope this helps!! =)
Old Jun 28, 2022 | 06:45 AM
leaddog11's Avatar
Good Morning Ken O!
C2Z28258
AJ814053
C2Z17429 (2)
C2Z17248
AJ813865
C2Z26930
AJ813917
C2D6362
C2Z18658
AJ811539
AJ813909-Water pump
How different would that be for 2013 xjl 5.0 na.
Thanks.
Garethster
May 21, 2021 04:12 PM
xtypejag502
Jun 16, 2016 01:09 AM
johnro6659
Feb 20, 2013 11:37 AM
Blakeb1
May 28, 2011 05:35 PM
Dangler2004
May 12, 2008 12:12 PM
