XJ ( X351 ) 2009 - 2019
Need part number
Old Nov 23, 2019 | 07:04 PM
machavaram's Avatar
Default Need part number
Hi recently i found out my 2013 xj is having a coolant leak and trying to figure out the part number. Below is where the leak is happening. Any suggestions on the OEM parts ?
Old Nov 24, 2019 | 11:37 AM
clubairth1's Avatar
Community Influencer
We need your car details? What engine?
Yes. Read about water pump replacement. You need to change all the plastic in your picture.
You have the old factory stuff with the big square glued seams. The replacement stuff will be smooth without the big square edges.
But the big question is can you DIY the repair? It's pricey if the dealer fixes it and you not under warranty.
Old Nov 24, 2019 | 11:43 AM
machavaram's Avatar
It's a 2013 XJ v6 3.0 base.
Old Nov 24, 2019 | 08:26 PM
Nedoerr's Avatar
I replaced the same coolant expansion tank hose due to a leak there too. Unfortunately the shop didn’t put the part number on my invoice. Sorry. Ended up following everyone’s advice and changed out everything.
Old Nov 24, 2019 | 09:20 PM
OzXFR's Avatar
I think it is part # 5 on this diagram, part # C2D6362: https://partsfan.com/jaguar/ww/12830.../12956/5#parts
I bought the exact same part for my F-Type about two years ago although I never got around to fitting it.
Old Nov 26, 2019 | 08:19 AM
machavaram's Avatar
Hi Yes, Thank you C2D6362 is the part number. The clamp only comes on the bleed hose assembly
Aceman123
Mar 3, 2021 02:15 PM
Swilmer52
Apr 28, 2019 09:01 AM
Scuba Steve
Nov 15, 2017 09:14 AM
Paolo78
Sep 8, 2014 04:15 AM
SJagR
Nov 22, 2007 09:20 AM
