XJ ( X351 ) 2009 - 2019
New engine - Help!
Old Mar 3, 2026 | 09:58 AM
L14GAV's Avatar
Question New engine - Help!
Hi everyone,
I'm looking for some collective wisdom on the current market value for a rather unique X351. I’ve owned this car for 2.5 years, and I feel it's a bit of a statistical anomaly!
The Car: Model: 2022 Registered (72 Plate) Jaguar XJL Portfolio.
  • The "Unicorn" Factor: As many here know, production ceased in 2019, but this unit was one of the very last to be registered. I think it is likely one of the youngest XJs on the road today.
  • Spec: V5 says Portfolio, but it’s a high-option launch spec: Rear entertainment screens, individual rear seating, massage functions, etc.
  • Mechanical Status: At <37,500 miles, the car suffered the dreaded engine failure.
  • The Good News: Jaguar Approved has provided 100% contribution for a brand-new crate engine. The main dealer is fitting it as we speak.
Whilst the chassis has 37.5k miles, the engine now has 0 miles, with the latest revised internal components from JLR to hopefully prevent any repeat.
Given that this is essentially a "new" 2022 XJL with the most expensive repair already handled by the factory, what do we think is a fair enthusiast price as it stands?
I see 2019 models with 50k miles asking £30k-£35k, but given the 2022 plate and 0-mile engine, would an asking price of £75k+ be seen as "collector territory" or wishful thinking?
Would love to hear if you think the "factory reset" on the engine adds a premium overall, or if the failure history is a detractor despite the brand-new replacement!
Old Mar 3, 2026 | 01:23 PM
doomtrain's Avatar
Value will be based on mileage and year of manufacture - what engine is it ?
Old Mar 3, 2026 | 01:46 PM
L14GAV's Avatar
It's a 3.0 diesel, zero miles and a 2022 (72) plate!
It is hard to value anyway because it has 3 years on all the others, but mostly curious of the value impacts (as in gone up/down or around the same)!
Old Mar 3, 2026 | 02:56 PM
Jaaag_drivah's Avatar
The only real collectible X351 is the XJR575.
Old Mar 9, 2026 | 12:33 PM
the-pm's Avatar
My unprofessional opinion is that a non-numbers matching car would decrease its value. However as it has had a brand new engine from Jaguar, I think this is quite harsh so it is worth the same as it had the original engine. If it had say 230k and then had a new engine in it then great but 37k should be "just run in miles" so not that valuable in my uneducated opinion. I would suggest valuing it as a 2022 with 37k on it and be able to explain to any potential buyer with a good story as to why it is a bargain with a new engine in it
More worrying for me with my XJD having 50k on the clock, what went wrong with the engine and am I on borrowed time
Old Mar 10, 2026 | 10:58 AM
TooManyJaguars's Avatar
Sadly, that particular diesel has a poor reputation for reliability in the best of circumstances 🙄
Old Mar 10, 2026 | 04:18 PM
Vasara's Avatar
Noup. You propably mix it for earlier 2.7 litre version what haved lot of issues, but still moderate versus many other.
3.0L version of AJD-V6 / DT20 engine is actually very robust but as any engine: Will fail if not serviced.
Mine have over 340t km (212t Miles) on odometer and still running with original MAF:s, EGR:s, turbos and exsample original waterpump. Engine running smooth, its dry and no issues in yearly MOT smoke test or starting up from -27C (-16F) temp. (noise it made on that temp is biblical)
Counting out service parts, oils, filters, belts and rollers i have changed three failed parts on engine bay: One solenoid and two intake plastic parts. (connection flange/joint between them failed) I would say Ford/PSA made really good upgrade from 2.7 litre to 3.0 litre version.
Change oils in max 15t km (9t miles) and use recommened low ash Castrol C1 oil and you are good.
MadManOfBethesda
Aug 6, 2023 03:41 PM
SCF
Jun 3, 2020 09:51 AM
Cbeny
Aug 31, 2017 10:30 AM
Quartzboy
Jun 12, 2016 01:27 AM
oakcircle
Dec 15, 2014 12:17 PM
