XJ ( X351 ) 2009 - 2019
Newbie headlight question.
Old Feb 23, 2014 | 08:12 PM
Cougarweeds's Avatar
Default Newbie headlight question.
Just picked up my 1st Jag and dream car on Monday. On a 2013 XJ the headlight appears to have 3 lights. The led's that run under the bottom, the outside lens that is the high / low beam, and then an inside light that looks like a disc of led's. What is this inside light and how do you turn them on? I can't find anything in the manual and the fog light button only operates the rear lights.
Thanks in advance.
Old Feb 24, 2014 | 03:50 AM
Welcome to the forum cougarweeds,
Is your vehicle fitted with AFS (Adaptive Front Lighting System)? If so you could be looking at the cornering lamps which are not driver switchable. I have these on my XK and they are very useful.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Feb 24, 2014 | 07:57 AM
Thanks Graham. I don't believe I have that feature as I haven't noticed the beams moving with the steering wheel. I assume the lens is still in the fixture even if the feature isn't active.
Old Feb 24, 2014 | 08:17 AM
edobernig's Avatar
Default New Feature- Directional signals
Thanks in advance.
That round array of led's inboard from the headlights are the directional signals. While they look clear, they flash amber when you activate the turn signal. They are super intense. Now on to more difficult features like mastering the voice control system or NAV. Enjoy your car.
Old Feb 24, 2014 | 09:22 AM
Doh! Thanks Ed, that was it.
I've had voice control on my last two cars and only used the phone features. I've found that although cool ideas, pushing the buttons is quicker.
David
Old Feb 25, 2014 | 04:56 PM
XJsss's Avatar
It is my experience that the LEDs are both turn lights and the high beams.
Old Feb 28, 2014 | 06:30 PM
johndahlheimer's Avatar
From: Mooresville, NC (Race City USA), home of most NASCAR teams.
Thanks in advance.
Being a North Carolina resident myself, I can understand why you don't know what these lights are. They are called "turn signal lamps", and even though we residents of North Carolina never use them (one reason we rank seventh in the nation for poorest drivers) those with higher intelligence and driving skills use them regularly in the civilized, non-retarded parts of the world,
Old Mar 1, 2014 | 02:31 PM
GilesGuthrie's Avatar
Sorry, but (at least on my UK 2011 car), this isn't right.
The inner disc of LEDs is the turn signal. Headlamps are a single bi-xenon bulb on each side that is adjusted for main/dipped beam. In the corner is a directional lamp that illuminates at low speed when cornering/signalling.
Old Mar 1, 2014 | 04:33 PM
XJsss's Avatar
Oops, you are correct and I was mistaken the headlights are as you described them GilesGuthrie.
Old Mar 7, 2014 | 09:45 AM
prawler's Avatar
I don't like the daylights of my JAG - they are hardly visible during the day...
Old Mar 7, 2014 | 10:16 AM
Welcome to the forum prawler,
hoodun
Nov 20, 2022 02:35 PM
trickeyM
Feb 29, 2020 07:00 PM
Msteiner
May 16, 2016 12:19 AM
Clare Jennings
Oct 4, 2015 05:43 PM
kevinl
Sep 24, 2015 08:25 PM
