XJ ( X351 ) 2009 - 2019
Not starting help!!!
Old Mar 6, 2023 | 04:14 AM
Abbas_ahmd's Avatar
Default Not starting help!!!
Guys I just topped up the coolant drove for like 20miles no over heating no error. Parked the car came back after an hour. It is not starting when you press the padel and push start button it just switched off no sound of starter
Old Mar 6, 2023 | 10:28 AM
Vasara's Avatar
When you have "black out" when pushing Start button, it indicates that your battery donīt have enough power to crank the engine. (or loose connection on terminal)
Old Mar 7, 2023 | 11:37 AM
Abbas_ahmd's Avatar
Update
It's too late now car was not starting. Suspected starter first now the garage guy told but the water on pistons on the left side engine. He have open the car head now in the morning he will open the engine next day. I am so lost as what to do it will cost alot to used motor. Shall I fix this one is guy said he will a company in the morning who check if can repair the block
Old Mar 12, 2023 | 08:44 AM
Abbas_ahmd's Avatar
Update found no good head to use so going with the one which was already there l. This is 5.0 V8 NA so I am not able to find any aluminum cooling hose or pipes. Most of the timing things are changed should be able to start the car tomorrow or day after. Will keep you guys posted.
Old Mar 21, 2023 | 02:04 PM
Abbas_ahmd's Avatar
Got the car back today somehow guy put the engine back and manage to run it. However I feel like there is something wrong the power is not that like before and he told me that I need to change the gear box. Which I have no idea if should or no because he said the car is keeping the gear for a time when you push the accelerator and release it after some time I felt that too while driving back home. In dynamic mode it feels better made it can be happening because of the engine or you think I should look at the gear to replace.
Old Mar 21, 2023 | 02:58 PM
Baltobernie's Avatar
Sell the car. Now that it is running, you won't have a total loss. Don't spend another dirham chasing (more) engine problems, transmission issues, etc.
bjg625
Jul 12, 2022 06:46 PM
Biff Baxter
Jun 24, 2022 01:00 PM
bjg625
Oct 1, 2020 08:16 AM
TweeTwee
Nov 10, 2015 01:56 AM
1 of 19
Nov 14, 2014 04:09 PM
