XJ ( X351 ) 2009 - 2019
One range colder on factory calibration.
Old May 8, 2020 | 12:54 PM
ricardoa1's Avatar
Default One range colder on factory calibration.
Contemplating running the NGK 96024 one range colder at 8 instead of the original 94940 at 7. I am a speed devil and foresee running a VAP tune and upper in the future. Since plugs such a pain and expensive to replace maybe this is the correct time to got one range colder in the event I upgrade in the future. Any I’ll effects, for anyone that has them any long term visual side effects, loss of MPG or fouling? I can’t imagine one range will make a big difference during non agressive operation?
Gap will be changed to .36, stock is .40 it seems.
Old May 8, 2020 | 02:23 PM
wombat's Avatar
I don't know the answer but, I'd start by asking the guys at VAP for some advice and looking at what the 575s are running.
wombat
Old May 8, 2020 | 02:29 PM
wombat's Avatar
Here you go!
https://www.velocityap.com/product/c...-supercharged/
wombat
Old May 8, 2020 | 02:30 PM
ricardoa1's Avatar
wombat
They run the stock plug but they run the same supercharger overdrive. The upper adds 1.5lbs.
Old May 9, 2020 | 07:48 PM
ricardoa1's Avatar
Decided to purchase the colder plug. Hopefully no issues will arise and MPG is the same. My winters are cold but not Artic cold. Colder is usually less risky than going hotter.
Old May 18, 2020 | 03:51 PM
ricardoa1's Avatar
Plugs came in and comparing and contrasting vs a stock plug. The porcelain is ribbed on the colder plugs, the tip will enter the combustion chamber further, on the plus side, the electrode is larger and so is the welded tip. I’m not sure how this is a colder plug by just looking at it. The electrode insulation enters the chamber more aswell. The gap is .020 on these and opening them up past .030 is making me uneasy. I measured the stock one and it’s at .036 not 0.040 like I see posted on the forums. I’ll be leaving it at .030. I think the tuning shops mention 0.025. Wish me luck :/
wimmer
Dec 22, 2019 08:58 PM
Unhingd
Sep 7, 2017 04:54 PM
Catsgame
Jan 19, 2015 05:00 AM
Philly Single
Apr 9, 2013 12:50 PM
mrcjr24
Sep 17, 2008 08:55 PM
