XJ ( X351 ) 2009 - 2019
P0342-64
Old May 18, 2021 | 02:50 PM
WhiteOw1's Avatar
Default P0342-64
Hello guys, jaguar xj 3.0 d 2011 my, can't start the car.
Story , i was driving my car and all of a sudden get a restricted perfomance(red) plus decreased power like turbocharger is not working. After that i parked my car on sideway and tried restart the car without results. Sdd shows p0342- 64 ( camshaft sensor problems) so may be someone can share their experience about changing camshaft sensor (DIY) -- I can't find it.
My English is weak but i hope understandable
Old May 18, 2021 | 03:22 PM
Vasara's Avatar
Camshaft sensor are in bit tricky plase. You have to remove airfilter box and maybe other stuff to get access it. The location are on side of cylinder head, front of exhaust manifold. Follow the oil-change pipe down about 20cm. It is well hidden, but if you follow electric wires you should able to find it. Sensor are held with one bolt, 8mm or 10mm if i remember right.
I hope it is the sensor or wires, not a timing belt jumped or snapped.
Old May 18, 2021 | 03:27 PM
WhiteOw1's Avatar
So is it real to reach cmp sensor without removing egr ? If i make a photo of under bonnet space can you show exactly where i need to look ?
Old May 18, 2021 | 03:29 PM
WhiteOw1's Avatar
And timing belt is ok at least visually
Old May 18, 2021 | 04:01 PM
Vasara's Avatar
Hello,
The sensor reads camshaft position from back of timing belt pulley. Airfilter side. I believe that you dont need to remove egr...
Check this picture, part nr 14. (bit poor angle on the pic)
Old May 18, 2021 | 04:10 PM
Vasara's Avatar
Ok, good.
I found one more pic what might help to locate it. On pic the belt cover are removed and sensor (blue) are seen thru canshaft timing belt pulley, The pic is instructions for install the sensor:
Old May 19, 2021 | 12:18 AM
WhiteOw1's Avatar
Ok, good.
Thanks for help, but it seems i wll need to remove timing pulley , ok today i remove airfilter block ,in case timing pulley removing is it difficult?
Old May 19, 2021 | 10:06 AM
Vasara's Avatar
Hello, no need to remove pulley. From front side you only see tip of sensor. The opening are not big enough for complete sensor go thru. The access and bolt are behind of pulley.
Old May 19, 2021 | 10:13 AM
WhiteOw1's Avatar
if i make a photo , will you show where is the sensor?
Old May 19, 2021 | 10:22 AM
Vasara's Avatar
This video might be usefull for you
On 14min15sek -> you can see CPS on bare cylinder head, without pulleys, cams, belts etc.The connector barely visible. Mounting bolt are where the connector are.
Old May 19, 2021 | 10:31 AM
Vasara's Avatar
Sure. Or we can maybe make an video call by Teams / Whatsapp? We can share contects by private messaging.
Old May 19, 2021 | 10:37 AM
Vasara's Avatar
From same video 23min:46sek.
Engine tilted on side, without exhausts, EGR:s etc.
You can see sensor, with mounting bolt and connector. I would 1st check and clean the connector.
I think this are the most clearest possible picture to locate the sensor.
superv803
Feb 13, 2022 10:21 AM
Mike-Ko
Jan 2, 2020 08:49 AM
kalacho2006
Mar 23, 2013 06:18 PM
kildare
Oct 30, 2012 03:41 PM
