XJ ( X351 ) 2009 - 2019
P2187 P2189 rough idling
Old Apr 14, 2021 | 09:37 PM
zidjan's Avatar
Default P2187 P2189 rough idling
Hey folks,
My 2013 5.0 has this engine light just came out of the blue... P2187 and P2189. It also seems like I am seeing some smoke coming from the passenger side tail pipe. I have a Icarsoft. Is there any livestream data I can check out?
Thank you
Old Apr 15, 2021 | 09:50 AM
Vasara's Avatar
Hi, both banks (ie all cylinders) too lean.
I suspect an airleak somehere after air flow control.
Old Apr 15, 2021 | 09:53 AM
zidjan's Avatar
Any Idea, how to check before I take it to a shop? the idle was running a little rough until I give it a little gas and suddenly everything is well. I tried cleared the codes and it seems to be running fine.
Old Apr 15, 2021 | 11:10 AM
XJ8JR's Avatar
You could check the fuel trims to see if it really is running lean. You could also check the fuel pressure.
Old Apr 15, 2021 | 01:06 PM
clubairth1's Avatar
Community Influencer
Several people have found the flexible plastic ducting from the air boxes can crack. Due to age and engine movement. Maybe a simple check of the plastic ducting can save you some money?
Since it's on both banks concentrate on the parts that are shared by both sides because we have two air boxes. I would double check the air box lids too.
Old Apr 16, 2021 | 09:38 AM
zidjan's Avatar
Thank you guys, I'll check for air leaks and report back.
Old Apr 21, 2021 | 09:45 AM
zidjan's Avatar
Update: took it to the mechanic and they confirmed that it's the PVC diaphragm. Turns out it's pretty common on these cars. It's all fixed now.
Old Apr 21, 2021 | 10:36 AM
clubairth1's Avatar
Thanks for reporting back. Yes that has started showing up more and more and looks like it will be a common but not to expensive repair.
Old Nov 21, 2022 | 09:08 PM
alison xenon's Avatar
how much was the cost of the repair?
2859bar
Jan 5, 2021 02:50 PM
Brautos1
Mar 20, 2019 09:53 PM
helo008
Dec 14, 2018 08:34 PM
Mickeyblue
Jul 27, 2017 06:04 PM
kbeachy
Apr 22, 2014 05:02 PM
