XJ ( X351 ) 2009 - 2019
P2402
Old Jan 13, 2026 | 01:11 PM
12jagmark's Avatar
... It appears that JLR does not service this separately from the fuel filler tubes either. In JPART it only lists the entire assembly (#6).
But that Ford part number (3M51-9B995-BA) does seem to be available and it does look like what you have.
Here is a brand new one for around $100 with shipping.
DMTL Filter
Originally Posted by Six Rotors
The pump on the cannister(which is mounted above the rear axle IS the DMTL pump. Check the Service Manual pictures--there is only one pump connected to the carbon cannister(called the EVAP cannister) and it is the DMTL pump. It draws air through a long pipe terminating with the DMTL filter near the gas filler pipe and cap.
Originally Posted by wombat
When I had my P2402 code on the '12, it was the carbon canister, and pump, mounted above the rear axle and not the DMTL pump. The piece of foam mentioned in the TSB protects the carbon canister from road spray and filth.
You may get lucky with just the DMTL pump, but...
wombat
This explains why the whole filler neck is included in parts to be replaced.
Ideally if the DTML filter performs well, it may fail without the DTML pump & carbon cannister getting damaged, and with luck just replacing the DTML filter might possibly and fortunately do the trick!
Jon89
Jan 29, 2019 11:44 AM
Wewillbfree
XJ40 ( XJ81 )
Apr 25, 2017 06:22 AM
Poet
Oct 28, 2015 06:25 AM
barondess
Sep 14, 2012 09:36 PM
daboss085
May 22, 2012 09:43 PM
