XJ ( X351 ) 2009 - 2019
Passenger door doesn’t Unlock
Old Jan 13, 2022 | 04:21 PM
jagsandgolf's Avatar
Default Passenger door doesn’t Unlock
The passenger door on my 2015 xjl does not unlock with the rest of the car. When I use the keyless entry on any of the other doors, all the doors unlock except the passenger door. If I go and pull on the passenger door using the keyless entry it unlocks and opens fine. It also does not unlock using any of the buttons, even the button on its door and I can see the light is lit that it is still locked. I can also open and unlock the door using the door handle on the inside. Tried looking for others with this issue, but couldn’t find any.
Old Jan 14, 2022 | 10:04 AM
clubairth1's Avatar
Community Influencer
You need to get the car hooked up to SDD and find what error codes your car has. These are too complicated to just start changing parts. Probably a door actuator but the codes will tell the tale.
But the big question is can you DIY the repair?
Old Jan 14, 2022 | 11:07 AM
I will hook it up and see what it says. It isn’t something I would want to replace myself, but I would like to have some type of idea of what it is before I take it in again. Thank you!
Old Jan 14, 2022 | 12:17 PM
clubairth1's Avatar
Yes the actuator is a good guess. We have had that reported before. It's not terribly common and some of the actuators are a SOB to get to to replace. Just depends on the door. Front doors are more complicated so more stuff in the way.
Old Mar 24, 2025 | 08:36 PM
EB777's Avatar
Where u able to resolve issue with passenger door ? Having same issues and car double beeping
FastCat85
Nov 13, 2021 09:16 PM
radjag1
Jul 23, 2020 09:37 AM
ian1975
May 8, 2012 08:53 AM
charm11
Feb 15, 2011 07:51 PM
