Permanently Disable Eco Start Stop?
Gentlemen: I would like to reopen the subject of how to permanently disable the Eco Intelligent Stop Start rather than having to push the off button at every fresh start. I have a 2014 Jaguar XJ (x351) 3.0 Liter RWD and find that the stop-start feature is a safety compromising distracting nuisance.
I have read the posts suggesting disconnecting the negative terminal of the small battery but wonder what else will be affected by that action or by the eventual discharge of that battery. Has anyone tried using any of the other stop-start inhibiting circuits such as disconnecting the brake boost vacuum sensor or using the trailer connection to fool the system into sensing the car is towing?
Since there were no adverse effects when my small stop-start battery died, other than a stop-start fault message, I think you can safely disconnect the negative terminal.
I like that feature and had a new battery installed to restore the stop-start functionality.
Your lucky as Stuart says because removing the battery cable from the small second battery in the trunk will do the trick.
Later versions don't have the second battery and you must reprogram it off. On my XJR if in Dynamic mode it also turns off the start stop stuff.
1. Gentlemen, thank you for the feedback.
After disconnecting the small battery, have any of you received an adverse reaction from the Jag Dealership when taking it in for warranty service? Any consequence?
2. Steve, smartstopstart.com, advises that he is focused on GM models at this time since they do not have a disable button at all and owners are clamoring for a solution. He says he's is considering Jaguar in the future.
I haven't yet gone to the dealer yet but I suppose you could simply reconnect it beforehand.
Edit: I actually just ran a scan and U0447 came up, which signals a fault with the Start/Stop feature. So yes it does trigger a fault code, but not one that will actually give you a CEL or something.
I would also love to see a permanent solution to this issue. I find it annoying in my Jaguar XJ and also my daily driver company car a 2016 Audi A3, the later I cannot do anything about though :-)
John
John
John, the correct technical solution is the one developed by Steve, smartstopstart.com. However, he has not developed the plug in Module for Jaguar yet. He says he is considering it for the future. I've been encouraging him via email. Check out his website.
Nope. That little ECO symbol is just going to be on your dash indicating eco stop/start is disabled no matter what. You will eventually ignore it and you won't even be aware of it after some time.
Do you need to click OK every time you start the car because of the Eco fault or will it stay unobtrusive?
I did look through the list of CCF modifiers in SDD and there appears to be no option to disable it at the dealer level either.
It may be that this question is one of the top 5 asked & answered question in the X351 forum.
You haven't seen a recent post (or 2) on this?
Browse through existing posts, you'll find it.
Jaaag_drivah, we don't know what you drive, so we don't know how your model is configured. My 2014 XJ does not require pushing "okay" or any other function button ever since I disconnected the ground lead to the small battery which disables the stop/start. The ECO symbol indicating it is disabled stays lit on my dash but keeping stop/start disabled requires nothing further. As an aside comment, I was worried about taking my car into the dealership when I still had warrantee and having the small battery disconnected so I installed a battery switch on the ground lead to the small battery in order to easily connect or disconnect it.
