XJ ( X351 ) 2009 - 2019
Radio issue
Old Sep 13, 2021 | 04:49 PM
Lbdltld1's Avatar
Default Radio issue
Hi all, I have a 2008 TDVI Sovereign. I cant activate the radio etc with my ignition off. If I turn the ignition on then all works fine.....any ideas? Thanks Lee
Old Sep 13, 2021 | 07:47 PM
Thermo's Avatar
Veteran: Navy
Lbdltld1, from the sounds of things, the switch side of your ignition switch is starting to fail and in this case, you are not making connection to supply battery power to the switchable wires. But, as you roll the key to the RUN position, you are hitting a different pad of the same circuit, which is then able to make contact and power stuff. But, this is where a shop will be able to confirm it.
Old Sep 14, 2021 | 02:59 AM
Lbdltld1's Avatar
Ok that's a bit technical for me I think so a professional may be my approach. Thanks for the info. 👍
cgaechief
May 12, 2021 07:09 AM
SamtheSham
Mar 28, 2020 08:08 AM
gagets
Mar 10, 2011 01:31 PM
