XJ ( X351 ) 2009 - 2019
Rain/humidity sensor
Old Jan 15, 2026 | 08:30 AM
whitejerabias's Avatar
Default Rain/humidity sensor
2016 XJL
Anyone successfully replace with a used sensor? Jag says you must use new, but of course they would. I understand how a module could be programmed to a specific vin, but just a sensor?
Old Jan 16, 2026 | 08:08 AM
Jaaag_drivah's Avatar
The "misting sensor" fault code is a common intermittent code on these cars. You may notice occasionally on a humid day that the windscreen fogs up even with the AC on. If it does not resolve quickly, that may be a result of a misting sensor fault.
The sensor should just be a direct swap with no coding required. Keep in mind that on some cars the installation of this sensor is a bit fiddly. Some vehicles use a clear gel or film to install this sensor so there is no contamination or dirt between the sensor and the windshield glass so the sensor can "see" rain properly. Think of it like "floaters" in your eye. Take a look at this thread: https://www.jaguarforums.com/forum/x...module-237240/
papatryk
XE ( X760 )
Nov 8, 2021 05:13 AM
Rubenspits
General Tech Help
May 14, 2021 01:31 PM
scottatl
Mar 9, 2021 06:07 PM
Ludovic Card
Jul 2, 2016 09:17 AM
Peperami
Mar 25, 2015 04:35 PM
