XJ ( X351 ) 2009 - 2019
Rear door wont lock
Old Jan 2, 2023 | 06:59 PM
RacingGreen87's Avatar
Default Rear door wont lock
Hello all,
I was taking out the child seat today and after i was done. The passenger side door wouldnt lock anymore.
The door latch is in the open position when i use a screwdriver to place the latch into the lock position it doesn't stay locked. Anyone have this issue is it a fuse or something. The other 3 doors work perfectly, Anyone know what this could be.
Thanks.
Old Jan 3, 2023 | 12:29 AM
NielsL's Avatar
The door locks on all 4 doors of these cars are unfortunately known to wear out. You will most likely need to replace the lock. Relativly easy diy job. Not so easy is to find the exact replacement part. The parts catalog is quite confusing when it comes to door locks. Chinese repro parts are available online, their quality compared to the OEM parts is unknown to me.
Old Jan 3, 2023 | 03:16 PM
I called the dealership today and they advised to replace both the latch and accuator is there a way for me to test which part went bad ?
Old Jan 4, 2023 | 12:12 PM
NielsL's Avatar
Only if you have a newer model with softclose, then you have a latch and a separate softclose actuator. I think if you have a newer model ordered without softclose, the actuator might be missing, but I am certainly unsure about that. The pre-facelift models have only a latch. Could a faulty softclose actuator produce your problem? Dunno. My suspicion would go to the latch.
Old Jan 5, 2023 | 12:37 PM
clubairth1's Avatar
Community Influencer
Yes if you have SDD it will tell you which one is bad.
RobertL
Oct 28, 2014 05:00 PM
AAJ
Jan 31, 2012 12:05 PM
jagmarine
Feb 7, 2009 05:54 PM
