XJ ( X351 ) 2009 - 2019
Recommended maintenance
Old Jan 1, 2024 | 02:59 PM
SAAlexander1985's Avatar
Default Recommended maintenance
My XJ is approaching 100k miles so I plan to do some preventative maintenance just to have a peace of mind. So far the plan is to do the following:
1) Replace plugs and coils
2) Replace plastic coolant tubes with aluminum
3) replace the rubber hangers for exhaust
4) probably crank pulley and sc pulley upgrade
my question is really what would yall recommend I add onto that list especially while I have the SC off to replace the coolant tubes
Old Jan 1, 2024 | 05:56 PM
clubairth1's Avatar
Community Influencer
Looks good! Maybe add all the rubber cooling hoses?
After doing #4 you will question why you had not done it a long time ago! Don't forget the tune!
Old Jan 1, 2024 | 06:11 PM
OzXFR's Avatar
Definitely replace/renew the water pump.
Renew both the SC coupler and SC oil.
Consider cleaning the intake ports and intake valves.
Consider renewing the PCV valves.
Old Jan 2, 2024 | 09:52 AM
Vasara's Avatar
Addind above what i would do also if unknown when done or service interval reached:
- Change the transmission oil
- Change coolant
- Change brake fluid
- Change diff oil
- Inspect the rear axle CV joints and replace grease. (all four of them)
Old Jan 3, 2024 | 04:31 PM
When you say SC coupler, are you referring to the plastic piece with the spring on it?
Old Jan 3, 2024 | 04:32 PM
Thanks for all the recommendations. Gonna start stocking up all the parts to knock out everything at once.
Old Jan 3, 2024 | 04:48 PM
OzXFR's Avatar
Yep.
Staatsof
Jul 28, 2023 01:16 PM
RochaSDS
Mar 27, 2023 05:28 AM
Blackcoog
Jun 5, 2022 08:36 PM
Etip
May 16, 2017 06:57 AM
